custom pulley setup!!
Old Dec 20, 2006 | 09:35 PM
dave3529's Avatar
dave3529
Default custom pulley setup!!
one of the ilder pulleys bearings was making noise, and of course nissan didn't want to cover it under the 60k "we don't hear anything" sooo, i took off the top idler pully and the tensioner pulley, made a nice custom tensioning method and threw on a shorter belt.
overall, no more noise, and definetly has a little better throttle response!
Attached Thumbnails custom pulley setup!!-100_0325654.jpg   custom pulley setup!!-100_032755.jpg   custom pulley setup!!-100_032665.jpg   custom pulley setup!!-100_0328565.jpg
Old Dec 20, 2006 | 09:42 PM
MR_X's Avatar
MR_X
good job. now go do a DIY
Old Dec 21, 2006 | 06:13 AM
first350's Avatar
first350
so you made the Alterantor pulley the adjustable one? (that's what the pictures look like)
-Peter
Old Dec 21, 2006 | 08:32 AM
dave3529's Avatar
dave3529
no actually i made both the alternator and the power steering pulley swing out for maxium adjustablity, its been three days now and been run perfect, knock on wood. ps i tryed doing just the alternator for the tensioning method but wasn't nearly enoghf, so its best with both. i'll put more pics up later
Old Dec 21, 2006 | 09:05 AM
THE TECH's Avatar
THE TECH
Yeah, you should really do a write-up on this.
Although...if you have a bearing problem, you really shouldn't add more tension to it, you should just replace it. The more tension you put on it, the faster it is going to wear.
Old Dec 21, 2006 | 12:32 PM
dave3529's Avatar
dave3529
no no, lol, the bearing that was whining was on the idler pully which i took off, and is now assigned to a box in the garage for a 1000 years to come lol.
Old Dec 21, 2006 | 12:41 PM
bbs350z's Avatar
bbs350z
nifty
Old Dec 21, 2006 | 12:54 PM
dave3529's Avatar
dave3529
these are the ****'s that i took off, i'll do a write up on it later tonight or tomorrow.
Attached Thumbnails custom pulley setup!!-100_0335-2-.jpg   custom pulley setup!!-100_0333-2-.jpg   custom pulley setup!!-100_0336-2-.jpg
Old Dec 21, 2006 | 05:43 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
yeah i am only running crank pulley and alternator with a hines joint to tighten it up replacing that gold bottom bracket.
Old Dec 22, 2006 | 10:50 PM
dave3529's Avatar
dave3529
Cool
ok, for anyone thats interested, heres how i did it, be prepared while it was a little noticable, it does take a 1/2 to 3 hours depending on ur skill. If i could do it over again it would be quick but since i was fabricating and figuring out what worked it took a lot longer then expected including 4 diff belts till i got the right one. which by the way is dayco #5060400, and can be crossed off at most part stores accept autozone because there stupid and told me it didn't exist when three other stores could order it and one had it on the shelf. anyway lol
* losen, and take off belt by using the bolt at the bottom of the belt tensioner.
*loosen and take out all the bolts that i highlighted in the pic below.
*take the belt tensioner and idler pully assembly off
*reinstall the just the bolts by themselfs to plug the holes so that no dirt or debree gets into the timing cover.
*install the custom braket on the power steering pump as showed in the pic below, and same concept on the alternator.
*put the belt on and tighten them up nice and tight or it may sqeel, did with me on the 5060405 belt, but not at all on the 5060400 belt but that second belt is a wicked pain it the a$$ to get on, fair warning ; )
happy 350'ing
Attached Thumbnails custom pulley setup!!-100_0333-2-3.jpg   custom pulley setup!!-100_032755-2-.jpg
Old Dec 23, 2006 | 10:24 AM
first350's Avatar
first350
thanks for the write-up!
Old Dec 23, 2006 | 10:42 AM
dave3529's Avatar
dave3529
no problem, i owe it to u guys to say the least for all the other usefull info on here.
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
