Stereo effecting the way the car runs??
Old Dec 27, 2006 | 04:39 PM
  #61
Jokestrap's Avatar
Jokestrap
Originally Posted by rocks
Read this it will explain it in more detail than i can.
http://www.aa1car.com/library/copign.htm
Dude, that is some pretty good information. Thank you!
Old Dec 27, 2006 | 04:43 PM
  #62
rocks's Avatar
rocks
As far as stero grounds i always ground my deck and amp to a diffrent spot, ground wires on them should not be over 24 inches long. You want them as short as possible. If the deck and amps are cutting in and out it could mean you need a bigger gauge power wire.
Old Dec 27, 2006 | 04:47 PM
  #63
Jokestrap's Avatar
Jokestrap
I am not sure about the grounds on the amps. It was a professional install. The power wires are 4 gauge. I bought a nice wire setup for the stall. This problem did not exist before they pulled out my motor and put it back in. It's been the same problem ever since with several EMS etc etc...
You could be right on the coil packs but I can't help but think that all this is related so the same thing.
Old Dec 27, 2006 | 04:57 PM
  #64
rocks's Avatar
rocks
If not coil packs then check the crank angle sensor. Sometimes these need shielding around the wires. On the nissan 240sx they have to be shielded sometimes.
Old Dec 27, 2006 | 05:04 PM
  #65
Jokestrap's Avatar
Jokestrap
Okay, will check it. Thanks man!
Old Dec 27, 2006 | 05:11 PM
  #66
rocks's Avatar
rocks
Some more information i found for you well it wont let me post the link thats freaking stupid.
http://www.air power systems .com .au
/350z/ecu/crank_signal.htm
Old Dec 28, 2006 | 08:08 AM
  #67
dTor's Avatar
dTor
Yes bad coil packs go in and out. Sometimes it will run fine and sometimes it will run like complete ***. There is still current going through them but its like a short, so it comes and goes...
+1
I've read others having the same symptoms of the coil packs working then not working then working again.
Old Dec 28, 2006 | 04:23 PM
  #68
Jokestrap's Avatar
Jokestrap
Originally Posted by dTor
+1
Okay, will do. I talked with the shop today and it seems that alt and coil packs would be the two issues at hand. I did not realize just how much the V-Pro overrides and negates. The limp mode issue is not realistic for this reason. It has to be spark (fire), the other one, fuel is good, and the rest is covered/overrided by the V-Pro.
I still have a crap load to learn about this stuff. It is good to know that the shop and some of you guys that have been through some of the challenges are here to assist guys like myself that are old hp guys. I am only 35 but it has all changed. The shop is on it and should be in there next week to get this stuff analyzed and resolved. Thanks for all the responses and help. Good forum for this stuff...
Old Jan 3, 2007 | 08:17 PM
  #69
MR_X's Avatar
MR_X
any updates?
bcoffee20
Nov 19, 2015 06:39 PM
SanmarinoZ
Oct 21, 2015 10:04 AM
kyin
Sep 29, 2015 06:57 AM
416blueZ
Sep 25, 2015 10:00 AM
z33z_nutz
Sep 23, 2015 07:22 PM
