Oil Psi?
Old Jan 5, 2007 | 09:55 PM
plastiketa's Avatar
plastiketa
Default Oil Psi?
What Psi should my oil be at during mid to heavy acceleration? I never noticed it before but I started hitting 90-120 psi. Does that sound right?
I'm running synthetic oil and recently have changed it with a new filter.
Old Jan 5, 2007 | 10:00 PM
Mike Wazowski's Avatar
Mike Wazowski
during hard acceleration in 3rd/4th I go to about 90psi. Usually never any higher when the car is warm.
@ 70mph in 6th gear I am at 60psi.
Old Jan 5, 2007 | 10:10 PM
plastiketa's Avatar
plastiketa
just as i thought. i know what I'll be doing tomorrow morning...
thanks for your help!
Old Jan 6, 2007 | 01:21 AM
Chad68's Avatar
Chad68
+1
The only time I ever see 120 PSI is if I blip the throttle a little when the engine is stone cold in the morning.
If I saw 120 under moderate acceleration on a well warmed up motor, I would kinda start to freak a little.
Old Jan 6, 2007 | 04:42 AM
Q45tech's Avatar
Q45tech
The critical oil pressure occurs in extreme hot weather* at idle...........other than that 10 psi per 1000 rpm is enough.
Oil pressure varies with brand of oil and it's real instanteous viscosity [temp curve]
*coolant at 200F and oil sump at 220F.............afterall the bearings/under piston crowns are running 300-350F.
Old Jan 6, 2007 | 07:44 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
So, Q-Tech, in hot weather at idle, what oil pressure should you be concerned about? 10 psi? 5 psi? 0 psi (obviously...)
Dave
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
