Going NA, and I need parts with the highest HP and TQ #'s
Old Jan 24, 2007 | 03:13 PM
  #121
ACEMAN's Avatar
ACEMAN
Master
Originally Posted by dougrace zs
You won't get the bigger #s unless you do cams, the plenum and the exhaust system are a restriction up to around 265rwhp after that you have to unrestrict down stream meaning the stock camshafts, at around 275rwhp the stock air box and the throttle body become the restriction. See dyno below.
Hey Doug,
Good to see you post in this thread.
If the stock cams for the 287hp engine are 238° duration, 9.2 mm lift (Intake), and 240°, 9.2mm lift (Exhaust). What are the specs for the cams you are using right now on your car?
Later
Todd
Old Jan 24, 2007 | 03:17 PM
  #122
98sr20ve's Avatar
98sr20ve
Which cams? Also, why is it everyone makes shorty headers and not the Long Tube. Crawfords seem to be the best shorty but I still always wondered why a group like them never went with a long tube as well. Any dyno info with Rev Up engines and the crawfords?
Old Jan 24, 2007 | 06:34 PM
  #123
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
dourace zs=Crawford
Why don't most companies make long tubes? Simple....much more time consuming, far more limited market Like most of the NA mods, people are just not going to fork up proper long tube money
Can Doug make em? Probably...I actually messaged them a few days ago regarding some, no reply yet
Old Jan 24, 2007 | 07:11 PM
  #124
matman99's Avatar
matman99
There's a really nice article about tuning shops in Japan and what they did for the Nismo Festival. Most of these NA cars don't just do 300, they're well into the 300's. Not every shop posted the dyno numbers for their cars, but they do list all of the mods. Very interesting stuff. You'll have to do some serious engine work to get in the low/mid 300's, not that anyone on this thread had any doubts. I think almost all of the cars had new heads, titanium valves, forged pistons, and obviously cams.
Regarding the topic of tb's, one of the cars, Autech Tsukada, had an interesting idea. They used a Q45 throttle body, removed the MAF altogether and used an FCon Vpro to take care of everything in the ECU (physical restriction eliminated :-) Anyone know if the UTEC would have enough control to do the same things to be able remove the MAF? Sorry for the newbie question, I just thought of this while typind and haven't tried searching yet.
Anyway the article is here, hopefully I'm not just reposting something everyone already knew about, http://www.jdm-option.com/eng/featur...2/z33_v35.html
Old Jan 24, 2007 | 07:18 PM
  #125
98sr20ve's Avatar
98sr20ve
Originally Posted by Z1 Performance
dourace zs=Crawford
Hoping that he sees some interest and changes his mind.
Old Jan 24, 2007 | 07:21 PM
  #126
98sr20ve's Avatar
98sr20ve
I printed that so I can read it just before bed and have sweet dreams.
Old Jan 24, 2007 | 07:29 PM
  #127
Z1 Performance
Former Sponsor
the MAF is not really the issue, though at a certain point, the throttle body might be. Where is that point? Who knows. More than one of the high hp cars NA in Japan is using a stock throttle body So, I think it's still anyone's guess at this point. Several of these cars are in that artcile, though that article is sorta antiquated at this point
Old Jan 25, 2007 | 05:03 AM
  #128
dougrace zs's Avatar
dougrace zs
Let me see if I can answer some of these questions. The cams we are running are 292, 11 mm lift intake cams 265, 11 mm lift exhaust they have to be advanced 8 degrees over stock after 4500 rpm, I would like even more aggressive cams but we are trying to do this and keep the CEL light off. On headers, our headers are quite a bit longer then most out there but there not as long as the xcerds, I don't think a longer tube header would help that much since our headers were eng dynoed against the longer tube headers and the short headers (Nismo) and they beat both of them. This was done by a race team and there very secretive so they would not tell me by how much ours beat the others, they just ordered 3 more sets. The MAF sensor itself would not be a restriction but the housing is so that’s why we have made a larger intake tube. Adam never got the message call me if you like 615-327-4159. Also I might mention we are still running a stock bottom end.
Old Jan 25, 2007 | 05:05 AM
  #129
Z1 Performance
Former Sponsor
thanks Doug - I'll try to give you a ring today!
Old Jan 25, 2007 | 05:27 AM
  #130
98sr20ve's Avatar
98sr20ve
they have to be advanced 8 degrees over stock after 4500 rpm,.
So I assume the Emanage Ulitimate is handling that task?
Old Jan 25, 2007 | 05:44 AM
  #131
dougrace zs
It does just fine,trying a U Tech at the moment to see if it's any better.
Old Jan 25, 2007 | 06:33 AM
  #132
nismology1's Avatar
nismology1
Don't mean to sound argumentative but what is the reasoning behind this?
Old Jan 25, 2007 | 06:36 AM
  #133
nismology1's Avatar
nismology1
I thought you got TS to flash custom cam timing onto your ECU...
Old Jan 25, 2007 | 06:39 AM
  #134
nismology1's Avatar
nismology1
The EU cannot control the VTC's directly; that's the V-manage's job (it will be released sometime early this year). To alter cam timing on the EU you have to use a roundabout way using the sub-injector maps. It's not an actual feature of the EU. Either way, due to the injector timing issues, it will only work in a small RPM window in the mid-range so i doubt the EU controls his VTC's.
Old Jan 25, 2007 | 06:42 AM
  #135
VandyZ's Avatar
VandyZ
No that is the TS reflash. He was using EMU for additional fuel and timing control. He has since started playing with the UTEC.
Old Jan 25, 2007 | 08:04 AM
  #136
dougrace zs
Sorry didn't read the quote correctly It is as Vandy said we had to have the stock computer flashed to increase the cam timing, The reason for this was we were trying to not set a CEL light with the large cams.
Old Jan 27, 2007 | 10:59 AM
  #137
Z1 Performance
Former Sponsor
Doug clear your PM's
Old Jan 29, 2007 | 05:34 AM
  #138
dougrace zs
PM's cleared thanks
Old Feb 3, 2007 | 09:36 PM
  #139
dave3529's Avatar
dave3529
with an intake and exhaust, if i put in a mild set of cams and had them tuned using a utec what kind of gains are expected on average? is tuning them the key to making a decent gain?
Old Feb 23, 2007 | 09:06 AM
  #140
filmnews's Avatar
filmnews
I have been looking at exhausts lately.
