8+whp for $12??
Old Feb 5, 2007 | 09:42 AM
bbs350z's Avatar
bbs350z
Default 8+whp for $12??
http://cgi.ebay.com/ebaymotors/03-06...QQcmdZViewItem
check that out, it says up to 8+hp at the wheels, and .3 sec in the 1/4 (lol). think this is a scam, or should i check it out, cuz its only $12?
Old Feb 5, 2007 | 09:45 AM
sq40's Avatar
sq40
The Coolant doesn't run near the TB??
Zridder19's Avatar
Zridder19
haha u gotta be kiddin wtf is that
Old Feb 5, 2007 | 09:47 AM
azrlee's Avatar
azrlee
To good to be true!!!!, Hope someone posts something about this subject!!
Old Feb 5, 2007 | 09:48 AM
booger's Avatar
booger
Yes there is a coolant line that heats up the TB . This kit bypasses it . Good in the summer or warm climates .
Old Feb 5, 2007 | 09:53 AM
bbs350z's Avatar
bbs350z
thats wut i was thinkin.
however a friend of mine (mind hes gm certified) runs coolant in his tb on his gto during the warm months, and it gives more power, but u run the risk of running either 2 rich or 2 lean. and u cant do it in the winter.
but i dont get how this would mak an improvement/ the only sort of cooling system involved w/ the tb that i can c working is water injection in the intake piping.
Old Feb 5, 2007 | 10:12 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
coolant runs through the tb, by bypassing it you dont run the hot azz coolant through it hence cooler air, and yes as booger stated only do in warm climates, as in colder climate this would allow ice buildup.
Old Feb 5, 2007 | 11:00 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Don't some of the plenum spacer kits include a by-pass?
Old Feb 5, 2007 | 11:11 AM
97supratt's Avatar
97supratt
I heard adding a volk sticker adds around 21 whp. So by getting two for $10 you gain 42 whp. Not bad at all.
BTW Nothing on ebay works if it says XXwhp!!!!
Old Feb 5, 2007 | 11:17 AM
Nexx's Avatar
Nexx
this mod doesnt really give you power but it can help you from losing power in the heat. i wouldnt do this if you're living in an area that can get into sub freezing temperatures frequently. i had this done to my car and ive had no problems in 20F temps.
Old Feb 5, 2007 | 11:22 AM
918 Z's Avatar
918 Z
yeah, the iso thermal kit comes with a bypass valve. if above 55 degrees u leave it closed, below u open it. it does make a big difference, compared with my friends kinetix i atually run a lil cooler to the touch.
Old Feb 5, 2007 | 05:40 PM
98sr20ve's Avatar
98sr20ve
Coolant keeps the TB from icing up in cold weather. Deleting it is great in the summer, possible dangerous in the winter. You can do the same thing with Lowes or some Autostores parts if you like. I have done it on my track cars in the past. Never bought anything from ebay to do it.
Old Feb 5, 2007 | 11:32 PM
DXJP's Avatar
DXJP
Why hasnt anybody ran nitrogen threw the tb. You want cold that would do it and you could set it up on NAWS solenoids like that inline cooler kit, But I doubt that makes any real power as the air charge is not there long enough to loose any real temps.
Old Feb 5, 2007 | 11:50 PM
michaeljr6's Avatar
michaeljr6
i had it on my plenum spacer.....motordyne sells it with the iso thermal.
Old Feb 6, 2007 | 01:52 PM
fat350's Avatar
fat350
no no no....we established that earlier in a different thread that RAIDER NATION stickers add the whp...
hahahha
Old Feb 6, 2007 | 02:59 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I prefer the kit that comes with motordyne spacers to that thing...
because the motordyne one isn't a permanent bypass
let me get one thing straight...you will NOT gain power. But yes, you might help prevent power loss due to heat soak. Like, a little tiny bit.
Old Feb 11, 2007 | 08:16 AM
Armitage's Avatar
Armitage
8whp is not going to improve your 1/4 mile time three-tenths of a second...
Old Feb 12, 2007 | 12:15 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It will if you learn how to launch after installing the mod!
Old Feb 12, 2007 | 04:42 PM
03redlineZ's Avatar
03redlineZ
I have the Iso Therm Plenum from Motordyne and it comes with a similar kit, which was specifically designed for the Z/G. It does work but not 8WHP!!
I dont know if you would see a difference on a dyno but in a track setting it would help out substantially!!
I have it set for off all the time there is a little switch to turn it on but my car doesnt see anything below 40 degrees. Having coolant run to the throttle is only needed for cars in cold conditions.
Personally I would get the Iso therm plenum or call motordyne for their set up dont get this off EBay unless you know someone personally that has this installed on their Z!
