engine dampener brace with turbo
Old Feb 20, 2007 | 11:17 AM
icedoutis's Avatar
icedoutis
Default engine damper brace with turbo
was wondering which turbo kits the stillen stillen engine damper brace works with, or if there is no issue with it. Am looking to get an aps tt kit (not set in stone), and also wanted the engine brace. Anyone have any info on this? Thanks in advance.
Old Feb 20, 2007 | 06:02 PM
MoodDude's Avatar
MoodDude
I have the APS TT and the Stillen Engine damper brace mounted in my car. Just takes time to fit it in place, it helps if you drain the power stearing fluid and remove the reseviour to install the damper.
Old Feb 20, 2007 | 06:14 PM
icedoutis's Avatar
icedoutis
thanks for the info kind sir
Old Feb 20, 2007 | 07:49 PM
i8acobra's Avatar
i8acobra
The new Ingalls damper will work with pretty much any turbo kit.
Old Feb 23, 2007 | 07:05 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
InGalls ETD "Stiffy" ~> https://my350z.com/forum/showthread....hlight=InGalls
Old Feb 23, 2007 | 10:42 PM
icedoutis's Avatar
icedoutis
Thanks, how you liking yours? also, kinda unclear as to if it fits with the aps STB? I take it they are working on that aspect of it? Or did they figure it out? Thanks
Old Jun 12, 2009 | 07:20 AM
SIR_pierre's Avatar
SIR_pierre
is there anything new on the market?
how does the InGalls work with a aftermarket engine sway bar?
i allready have a brand new stillen damper that i cant fit becuse of my GReddy TT
MoodDude..do you have pics of yours?
Old Jun 12, 2009 | 07:37 AM
Spork's Avatar
Spork
Ingalls dampener doesn't work with the Cusco strut bar for sure.
Old Jun 12, 2009 | 07:40 AM
SIR_pierre's Avatar
SIR_pierre
why is that? i have the Circuit Sports Dry Carbon Strut Bar
Old Jun 12, 2009 | 07:49 AM
Spork's Avatar
Spork
It won't bolt up. A local friend tried and now has the dampener collecting dust.
Old Jun 12, 2009 | 07:52 AM
SIR_pierre's Avatar
SIR_pierre
ok..becuse my thought as that this little brace will lift the one side/end on the strut bar..and without a spacer for all the other 6 bolts then there wil be some tension ( dont know if thats the correct word) and if i dont have a adjusteble strut bar then it perhaps wont work at it best
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
