Clutch click on release of pedal
Old Feb 21, 2007 | 03:50 PM
malcolmsmith's Avatar
malcolmsmith
Default Clutch click on release of pedal
My '05 Z Roadster has a clutch noise problem. When I release the clutch pedal it makes a clicking noise. Anyone had this problem before? Any fixes before I have the dealer replace the whole clutch mechanism? Thanks in advance for your help.
Old Feb 21, 2007 | 04:12 PM
tylerdurden07's Avatar
tylerdurden07
sound clip?
Old Feb 21, 2007 | 05:52 PM
GolfinZ's Avatar
GolfinZ
mine does the same but I dont know if its a problem or not???
Old Feb 21, 2007 | 06:53 PM
Cheezwiz's Avatar
Cheezwiz
It might be your rear axle, check the TSBs.
Old Feb 21, 2007 | 07:09 PM
gatti-man's Avatar
gatti-man
If its like a light popping sound it will wear away with time. I had the sound from around 4k-10k and now its gone.
Old Feb 21, 2007 | 07:11 PM
bb1314's Avatar
bb1314
da Terminator!
Do a little search and you will find a gazillion posts on this topic. My car did the same thing and the dealer "grease" something up for me and it went away for like 1k miles. It came back again and now I just turned up the radio and ignore it.
Old Feb 21, 2007 | 07:58 PM
Bevo's Avatar
Bevo
I see, i have the same issue. Hope it will just go away like you guys said.
Old Feb 22, 2007 | 08:02 AM
BiGGD198's Avatar
BiGGD198
That clicking noise is most likely your throw-out bearing on the clutch. I have the same problem with my car but i ignore it until i change my clutch because replacing your throw-out bearing you might as well replace the clutch cuz your doing a lot of work.
Dan
Old Feb 22, 2007 | 08:09 AM
g356gear's Avatar
g356gear
It was my clutch pedal assembly under the dash that needed a little grease. Fixed.
Old Feb 25, 2007 | 07:05 PM
gatti-man's Avatar
gatti-man
so weird how my dealer said there is no grease fix. ah well its gone anyways. funny thing is as soon as my clutch stopped popping my dash started rattling!
Old Apr 24, 2007 | 02:21 PM
spacemn_spiff's Avatar
spacemn_spiff
Where exactly did you grease it? I have the same click which I think is coming from the spring in the pedal assembly.
Thanks.
Old Apr 24, 2007 | 02:32 PM
Conrado III's Avatar
Conrado III
i have that problem 2 somebody said something bout my rear drive tran kinda werid
Old Jun 20, 2007 | 02:14 PM
shanecrosby's Avatar
shanecrosby
where did you grease the pedal assembly? my clutch pedal sticks about an inch from the top of fully disengaged. I can lift it up the rest of the way with my toes though.. I'm wondering if there is a spring or something that is sticking underneatch the dash...
Old Jun 20, 2007 | 06:42 PM
NismoZ03's Avatar
NismoZ03
My clutch started clicking at about 50k, dealer said nothing they could do. Then at about 70k is started to squeak like an old bed. I couldn't deal with it anymore so the dealer greased it up for $40 and it was gone. For atleast 200 miles, now its back again. Any thoughts...
Old Jun 21, 2007 | 09:04 AM
shanecrosby
Umm... Nissan service sucks azz? I'm waiting on others to chime in with some ideas on this thread too:
https://my350z.com/forum/showthread....128253&page=19
Old Jun 27, 2007 | 06:32 PM
CONANN's Avatar
CONANN
i Have that problem to
and i had the rear axle clicking aswell
got the rear axle problem fixed by nissan,
and the clicking from the cluthc is definately somethin diff
but i dun think its any thing and also learnt to ignore it
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
