Before and after bolt-ons dyno!
Old Feb 25, 2007 | 12:23 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by streetracer
i did injen ses, alpha test pipes, spacer, jwt pop, and the re-worked drivetrain.
First congrats on using the dyno correctly. Too many owners aren't true tuners and just mod than dyno and get disappointed.
Second I'm not understanding how you only gained 9whp from; TP, Cat-back, Spacer, Intake, and whatever drivetrain you did.
I would expect at least 15-25whp from what you done. You might need to get a tune to get the best power out of everything.
Old Feb 25, 2007 | 01:11 PM
streetracer's Avatar
streetracer
Originally Posted by Cannysage
what kind of testpipes you got? if it's no name, get a good reputable brand plus UR crank pulley. I can almost guarantee that you'd gain good power.. It almost appears that you're losing power somewhere and I'll bet it's your exhaust system..
The test pipes are resonated alphawerks. T-304 SS. They seem to be very good quality. Welds are the same quality as the Injen SES true dual. The injen exhaust is dual from the test pipes without equalizing H pipe.
Old Feb 25, 2007 | 01:16 PM
streetracer
Thanks for the props on the dyno usage. I'm skeptic about this 9whp thing because I improved my 0.25 mile time from 14.3@100.5 to 13.9@102.1. Maybe its my 3.9 FD and not hp, who knows...
Question for ya': Do you think a Utec would increase my power enough to justify the cost of purchasing it? How much power gain would you say I'm looking at with the Utec?
Old Feb 25, 2007 | 01:19 PM
Ahmads350z's Avatar
Ahmads350z
Originally Posted by derek173
We also do dunks
o god!
Old Feb 25, 2007 | 04:18 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well the 3.9 gearing helped a lot in the 1/4 for sure! I'm jealous that you have the 3.9 but I plan on TT so it wouldn't do me any good.
As far as the UTEC, it more than just added power. Speaking for myself after my mods my motor was running dangerously lean. Please take into consideration though I'm at 5k+ feet elevation. However it is alway good to tune to have a safe running motor. That is the number one reason I purchased my UTEC. The plus to tuning to have a safe motor is freeing up hidden HP. Now my peak numbers didn't go up at much as I wanted but my mid-range went up between 5-10whp/wtq! Plus with owning the VQ35DE I raised the rev limit to 7k vs the 6800 stock. I'm sure once I get a full cat-back my peak number will go up. All-in-all... YES! The UTEC purchase & tune is worth the cost.
Old Feb 27, 2007 | 12:19 AM
rct350z's Avatar
rct350z
aem cold air intake + skunk2 plenum spacer + greddy evo2 exhaust got me 271 whp on a dyno dynamics
Old Feb 27, 2007 | 12:28 AM
Cannysage's Avatar
Cannysage
your sub 14, 1/4, is all with your FD and LSD. you seriously need some upper end power. I personally wouldn't trust alphawerks and Injen. I'd swapped them out with kinetix tp or crawford cats , along with any other trusty exhaust.. hks, if you can swing the $$, add a ur pulley and you're good to go, I dyno'd 284whp on dynapack sae corrected, without cams. 20whp gain came from my hks true dual, kinetix and ur pulley. good luck.
Old Feb 27, 2007 | 05:00 PM
streetracer
well some good news: I just raced a modified mini S that i used to race when i was stock barely pulling half a car in fifth gear. This time i pulled on him more than five cars from third all the way to sixth. he stopped me and said, that car is running much better. the difference is noticeable.
Old Feb 27, 2007 | 11:20 PM
Fluid1's Avatar
Fluid1
The 13.9 is with all the mods you have?? That seems strange as I also have a 03 base and went 13.8 the only time I ever raced, and I was 100% stock other than a front sway bar....
Good to hear that your car seems to be pulling better, but I'd be careful with anything related to street racing right now, people are on a witch hunt!
Old Feb 28, 2007 | 01:55 AM
streetracer
Really, that sucks for me. How much did you trap?
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
pdexta
Sep 14, 2015 11:27 AM
torchkc
Sep 11, 2015 08:26 PM
