what do u think about this oil cooler
Old Feb 27, 2007 | 12:04 PM
joe~075's Avatar
joe~075
Default what do u think about this oil cooler
starting to look for a cooler and came across this one what do you think.
good price too.
http://www.glowshiftdirect.com/index...ROD&ProdID=275
Old Feb 27, 2007 | 12:40 PM
LaoSiFu's Avatar
LaoSiFu
I am also interested when I came across it on eBay. Hope you don't mind, I would like to subscribe to this too.
Old Feb 27, 2007 | 12:45 PM
THE TECH's Avatar
THE TECH
Looks good, who knows about quality. I went with the Stillen/Setrab setup just to make sure it was all quality.
Old Feb 27, 2007 | 02:50 PM
MoodDude's Avatar
MoodDude
I am the firm belief in the less fittings you have the less problems you will have with plubing. This unit has numerous fittings to get the job done. Also, it says that they use a 7/8" diameter hose, let see you fit those hoses on the Z (Those are AN14 size hoses!).
If you want a quality job, make your own with race proven quality (Setrab is a great one, and there are others). Also on plumbing - stick with Aeroquip or Earl's, if you don't want to spend the money than you shouldn't put an oil cooler on the car. And Stillen's kit does use minumum fittings and high quality hose and cooler, the only thing I don't like about it are:
1. It has a pressure bypass on the sandwhich plate
2. It uses AN8 hoses, I prefer AN10 hoses for this application. Although 8's will work very well.
3. The design pumps the oil first through the cooler than through the filter. A properly designed system would first put the oil through the filter than through the cooler.
4. It still uses the stock filter that has a pressure bypass on it (no matter what brand you buy).
That said, if this is for a street application, than Stillen is the way to go. If you are looking for higher quality and a better design, you need to build your own system (yet this would only be if you have the money and/or race).
Here is a great web site if you want to build your own:
www.HRPWorld.com
Old Feb 27, 2007 | 04:41 PM
peptidbond's Avatar
peptidbond
Nice, nice comments from MoodDude.
I would also highly recommend that the filter adapter be thermostatic if you live in a temperate climate and plan to leave the cooler installed all the time. The thermostatic type will only send oil to the cooler if it reaches 185 degrees. Trust me, you don't want to send oil to the cooler if you are just cruising in winter temperatures. The oil might not ever reach operating temperatures, which is just as bad as cooking the oil.
Old Feb 28, 2007 | 05:03 AM
joe~075's Avatar
joe~075
thanks everyone for your reply it was helpfull.
Old Feb 28, 2007 | 05:17 AM
JDMFairlady21's Avatar
JDMFairlady21
mr.joe whats going on? have you checked the announcement we made?we're ALOT closer to you now! LoL just got my phone fixed after a long issue with nextel... gimme a call sometime.
Old Feb 28, 2007 | 05:34 AM
98sr20ve's Avatar
98sr20ve
www.HRPWorld.com
Never mind unless you are running on a roadcourse you are hurting yourself by putting a cooler on the car. Over cool oil is bad not good. Even a thermostat on the cooler will not let your oil reach temp as quickly as a oem setup.
Old Feb 28, 2007 | 05:44 AM
joe~075's Avatar
joe~075
whats up alex ? i stopped by vinnys new shop yesterday looks good and he just got the hydra in i wonder what i should do anyone meeting up today?
talk to ya soon.
Old Feb 28, 2007 | 05:49 AM
joe~075's Avatar
joe~075
98sr, even if i am FI car heats up fast.
Old Feb 28, 2007 | 07:52 AM
JDMFairlady21
big meet tonite joe... come out! i'll be in the shop soon as i get my cubicle! LoL
Old Feb 28, 2007 | 09:37 AM
98sr20ve's Avatar
98sr20ve
Do you track your oil temps? Thats stage one. Oil takes about 3 times longer to get to temp then radiator fluid. Don't guess, get the gauge first.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
