Mobil 1 Oil Users - Motor oil discussion thread
Old Apr 10, 2007 | 08:44 AM
  #201
MustGoFastR's Avatar
MustGoFastR
Damn, the GC is disappearing? Just when I'd decided to switch to it... I bought 5 qts a few weeks ago for my next change; maybe I need to go back and clean off the shelves if they have any left...
Old Apr 15, 2007 | 07:48 AM
  #202
hercules350z's Avatar
hercules350z
I went and check out the Amsoil website, there are so many types and choices of synthetic oil. Which one is the right for our Z's? Please advise!!!
Old Apr 15, 2007 | 09:40 AM
  #203
JonsilvZ's Avatar
JonsilvZ
I think Mobil 1 and Castrol syntec are the best. Because BP Amoco makes Castrol and Exxon makes Mobil 1. The 2 largest oil companies in the nation.
Old Apr 15, 2007 | 09:50 AM
  #204
Nexx's Avatar
Nexx
yes and GM makes the best vehicles on the planet because they are the largest automaker in the world.
Old Apr 16, 2007 | 03:08 PM
  #205
03BlkSETE's Avatar
03BlkSETE
This is the Group IV oil that is often talked about in this thread.
https://www.amsoil.com/storefront/Se...x?CategoryID=1
You can get a better price from this guy.
http://forums.maxima.org/showthread.php?t=480065
I've been dealing with him for about 3 years and he's been on Maxima.org site for several years with flawless customer service.
Old Apr 16, 2007 | 06:22 PM
  #206
merlin3's Avatar
merlin3
i want to switch to amsoil but do you think that 0w30 might be too thin for a twin turbo car?
Old Apr 16, 2007 | 07:39 PM
  #207
nissan350zfan's Avatar
nissan350zfan
Originally Posted by derek173
I have been in several threads disccusing oil so I felt I needed to make a post for M1 users. I am not bashing M1 just hoping to educate my fellow VQ people.
After I started to track my car, I began looking into information about the best oil to use. During my research I found several examples of M1 showing high lead content (bearing wear) in used oil analysis on Vq35 engines.
I know M1 is considered to be the best oil, but it never was a good oil for the Vq35 engine. Another reason to not use M1 would be that it is no longer a true synthetic. Several months ago they changed their formula.
Mobile1 is no longer a true synthetic
Mobil sued Castrol for calling their oil a full synthetic. Which according to Mobil it wasnt a full synthetic like M1 since its not made from a Group IV base stock.
They lost the case, so they decided to start using the cheaper base stock just like Castrol,pennzoil etc. Why make a real synthetic that costs you more money to make then the competition who is charging the same price for their fake synthetic?
German Castrol Syntec 0w-30, Amsoil, redline are some of the few remaining TRUE synthetics( Group IV). The other Castrol syntecs, penzzoil platinum and now Mobile 1 are not TRUE synthetics. They are hydrolocked Group III oils.
Here is an example of how even yellow bottled Pennzoil Dino outperformed M1 in our engine.
M1 used to be a great oil, now its an overpriced fake synthetic. My current fill is German Castrol Syntec 0w-30 (auto-zone only). Unlike the other castrol syntecs it is a true Group IV oil, here is an oil analysis on a G35 coupe. As you can see this oil shows very little wear after 7500 miles.
Code:
Element            This        Last     2nd to Last        Universal
            Sample        Sample    Sample         Averages
Aluminum        2        1        2        3
Chromium        0        0        0        1
Iron            5        2        7        11
Copper          5        3        6        7
Lead               2        1        3        5
Tin             0        0        1        1
Moly            4        3        1        75
Nickel          0        0        0        0
Manganese        0        0        1        0
Silver           0        0        0        0
Titanium         0        0        0        0
Potassium        1        0        7        1
Boron           0        1        1        64
Silicon          8        7        9        11
Sodium           9        8        1        7
Calcium         2643        2504        2520        2296
Magnesium         106        111        103        115
Phosphorus        687        660        635        705
Zinc             857        762        789        840
Barium           0        0        0        0
TBN            2.6
Test :    Vis        Flash    Fuel    AFZ    H2O    INSOL
    @210F        Deg F    %    %    %    %
Shd Be:    58-65        >385    <2.0    0    <0.1    <0.6
This:    61.9        415    <0.5    0.0    0    0.3
Sampl
(edited to make more readable)
I am skeptical that the lead and iron numbers you have highlighted prove anything. What about the readings for Moly, Silicon, calcium, phosphorous and zinc, which are all higher with penziol? Also, how do you reconcile the difference in mileage between the Mobil and Penziol tests? How hard were these cars driven and in what conditions? The only way you can draw conclusons from such tests is to have two identical vehicles driven in similar conditions in similar driving styles. Otherwise the data is not comparable and any conclusions are suspect.
There are many studies out there that demonstrate that, except for extremene cold conditions, the type of oil is not the major factor in engine wear. Rather, it is the frequency of oil and filter change that is the significant factor in engine life.
Old Apr 30, 2007 | 11:06 AM
  #208
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
hey guys 3 of us here just changed our diffs/and engine oil using amsoil. ts0 0w-30 for engine, all i can say is wow i def can tell a difference, runs alot smoother. i initially had mobil 1, then swapped to royal purple which i couldnt stand as it seemed to burn off quick and get dirty quickly. we will see how it does as i know one of use is sending it to blackstone when the time comes.
Old Apr 30, 2007 | 08:21 PM
  #209
mechachrome's Avatar
mechachrome
How long do Blackstone tests normally take to get back?
Old May 1, 2007 | 10:15 AM
  #210
shushikiary's Avatar
shushikiary
Mine have always come back within 1 week from the day I mailed it out....
Old May 1, 2007 | 02:33 PM
  #211
desiZ's Avatar
desiZ
Sent mine in yesterday... ran 4000 miles on mobil 1 10w-30 clean.. (regular dino oil)... replaced with castrol syntec (full synthetic) 5w-30 and will resend in 5k miles to see the difference...
Old May 1, 2007 | 04:15 PM
  #212
Bevo's Avatar
Bevo
All Mobil 1 are synthetic, i think you meant Mobil Clean 5000 or 7500
Old May 6, 2007 | 10:59 AM
  #213
scotts300's Avatar
scotts300
Other threads seem to differ, as they ARE saying that M1 is now a Group III blend, no longer Group IV.
Old May 6, 2007 | 07:52 PM
  #214
redlude97's Avatar
redlude97
Yes, but group 3 oils are still considered synthetic, but not as good as group iv based synthetics. Most of the other synthetics on the market are group 3, castrol, penzoil etc.
Old May 7, 2007 | 04:43 PM
  #215
JonsilvZ's Avatar
JonsilvZ
My point is I always use BP or Exxon gas and its great. So are the oils. GM quality is not good from my experience.
Old May 7, 2007 | 05:26 PM
  #216
farobaba's Avatar
farobaba
+1 with exxon, i used Wawa gas few times, and i noticed how the MPG droped.
Old May 8, 2007 | 09:54 AM
  #217
nlsqba's Avatar
nlsqba
another oil test: http://www.animegame.com/cars/Oil%20Tests.pdf
I am currently using valvoline and I am happy. Seems like the engine works better then on castrol.
Old May 8, 2007 | 11:11 AM
  #218
shushikiary
what year is this publication?
Old May 8, 2007 | 11:27 AM
  #219
nlsqba's Avatar
nlsqba
I have no idea - found this on R6 forum
Old May 8, 2007 | 12:11 PM
  #220
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
That test is like 10 yrs old. Mobil 1 hasn't made those bottles for years.
