Mobil 1 Oil Users - Motor oil discussion thread
Originally Posted by Fluid1
If you get a diagnostic test on your oil, and the M1 works for YOU, then YOU should be fine. No 2 engines are the same, and if what you use works, why change?
While it may be okay, I would do one oil change about every 6 months.
derek173, i'm starting to think you work for Castrol?? How much comission are they paying you to sell their product?? LOL. Seriously though, good info man. Thanks for taking the time to lay this all out for us!
Originally Posted by derek173
Why?? M1 makes an oil that is guaranteed for 15k, why not run the superior GC for 8k? Synthetic doesnt get affected by the age of the oil as much as regular dino. Oil in general has come a long way.. dont believe everything you have heard.. the days of 3k or 3 months on an oil are dead
Hey, you want to test the boundaries? Great. Better your car than mine.
P.S. find me a filter that can take that kind of abuse. Your system is only as good as it's weakest component.
Mobil 1 WAS a great oil, but it never showed good results on our engines.
Thanks a lot for the in-depth analysis. I would like to give this stuff a try too. I assume they also make a 5W-30?
All the stuff I've read about mobil (mobil1, mobil clean etc) oils on bobistheoilguy forums led me to believe that mobil is overpriced, overmarketed junk
Originally Posted by thawk408
Greddy twins on the stock block for only 3500 miles.
And you've missed the threads when other people had the same issue with the Greddy kit on stock blocks? lawl
Did you have an aftermarket pully?
It's a little bold for you to say 'never' isn't it? Unless, of course, you have diagnostic results from oil tests from every VQ that's ever run M1.
M1 was a great oil, but it just wasnt a good oil for the Vq35. Get back to me when your done with your research.
Just called my local Autozone and asked for a price of the greman castrol and they were like "what?? we don't have that...... HU are you sure it's german"
What specifically should i ask for. Is it castrol 0w40?
I spoke with some young guy cause he was talking to someone else in the background as was saying "wow dude it's like totaly fast and i bet the tires smoke threw 4th gear and stuff" I Hate smart A$$ young guy's
thanks for the info, i just passed it on to my buddy who just put M1 into his 07WRX LOL
Cheers
Kevin
Cheers
Kevin
True. But the days of one YEAR and 8k miles are not 100% confirmed.
I already posted a UOA on German castrol syntec that was run for 7500 miles with excellent results. It could have easily been run to 10k.
What specifically should i ask for. Is is castrol 0w40?
Cheers
Kevin
Cheers
Kevin
No problem I am not a brand *****, I also use Pennzoil platinum and Halvoline maxlife synth. I like GC because its locally available, and is just as good as amsoil.
Originally Posted by Cannysage
where did you get $6? i pay $2 a quart at walmart.
For those worriesd about running a 0W oil
Thin Oil Myth
Created: April 10, 2006
Disclaimer:
All the temperatures here are in celcius.
Short answer:
0w-30 and 5w-30 can be thicker than 10w-30.
Long answer: Read below.
Really Basic (but not so intuitive) information:
I'm sure we have all seen 5w-30, 10w-30, 10w-40, 20w-50, but what does it mean?
When talking about viscosities, you must state the temperature.
Lets break this up into two categories: hot and cold.
Xw-20, Xw-30, Xw-40, etc (HOT!)
This is your oil's hot viscosity. The viscosity is measured @ 100c.
This number is relative when the engine is warmed up.
The most common unit is cST. The larger the number, the "thicker" the oil.
Examples
A "30" weight is between 9.30-12.49 cST @ 100c.
A "40" weight is between 12.50-16.29 cST @ 100c
"Why isn't 5w-30 or 0w-30 thin?"
I think a real-life example will help.
Lets compare Mobil1 5w-30 to Mobil1 10w-30.
First the Hot (100 c) setting
Straight from Mobil1's datasheet (Looked on April 4, 2006):
5w-30 = 11.3 cST
10w-30 = 10.0 cST
Looks like the 5w-30 is thicker! (Notice how both oils are a "30" weight)
Now lets look at the cold setting
Based on the 5w and 10w specifications:
5w-30 = 6600 cP or less @ -30c
10w-30 = 7000 cp or less @ -25c
Looks like 5w-30 is thinner than 10w-30!
We can conclude that:
5w-30 is thinner than 10w-30 at -25c.
5w-30 is thicker than 10w-30 at 100c.
The above implies that 5w-30 thins out less than 10w-30 as temperature increases.
My main points are:
0w-30 can be thicker than 5w-30.
Thin Oil Myth
Disclaimer:
Short answer:
Examples
5w-30 = 11.3 cST
10w-30 = 10.0 cST
My main points are:
Well, the information you posted is basically correct, but I'll add some things:
If you are running a 5W-30 versus a 0W-30, those 2 oils start from different base stocks of different weights. Multi-weight oils are basically oils that have polymers attached to them.
I believe in race applications, most of the time they don't use multi-weight oil because they don't want polymer in the engine (I could be wrong about this though...) for example, race motors might use a 30W oil (non-multiweight).
When COLD the polymers are coiled and the oil will behave basically like its base oil (first "W" number).
When HOT the polymers uncoil, making the oil thicker and it protects SIMILARLY to an oil of weight noted after the dash.
So a 0W-30 protects like a 0W (non-multiweight oil) when cold, and protects like a 30W oil when hot.
In order to make a bigger spread between the first "W" number and the second number (after the dash), they need to add more polymer.
So basically... IMO it is better to use an oil that has a tighter spread. No engine benefits from having more polymer in the oil, so you should pick an oil that is closest to the weight you need. Since polymers can shear off their oil molecules, there's a possibility for them to burn up and make deposits in the engine...
That is why I'd rather put a 5W-30 in the car (less spread between the numbers) than a 0W-30...
This is just what I choose to believe, not that I think you're going to be FUCT if you use a 0W- but I'd rather have a little more protection when cold.
I know they should theoretically protect the same, but the 5W-30 will have less polymer in it, and will also be a bit heavier when cold, preventing some of that burn off when the engine is cold.
You can have your opinions about the weight of the oil you choose. But my research has led me to believe that you should pick a multi-weight oil with the minimum spread that fits your application.
Originally Posted by sunmind
Thank you for taking the time to provide the information about Mobil 1
I have used Redline on my high-revving hotrod, but it is hard to find.
Since the jury is out on the Rev-Up engine oil consumption issues, I am staying with the dino product for now.
Have been using Mobil 1 in my Range Rover, here in the hot climate. Will try and find the Euro Castrol. Not sure what grade to buy though... ideas anyone..?
here are the replys
In general, he is correct, especially with dino oil. Synthetics need less VII (polymer) to achieve a multi-weight function. The less VII in the oil, the more stable.
I do believe, though, that all 0W30 oils are at least semi-synthetic.
Polymers have come a long way from what was used in the 1st multigrade oils, where much of the worn polymer deposits stories come from. Most engines will benefit more from a multi-visc oil vs. single weight, despite any supposed problem with added polymer, IMO. Sheared polymer isn't completly dead either, there have been tests that show some antiwear ability from it's presence. I do agree though that too much of anything is not a good thing.
This post is from a moderator on the oil forum, He ran several UOAs on his G35 with German Castrol. His UOA is the one I have in my first post
Derek, there are some pretty serious problems with that. It seems to show a half-baked understanding of what's going on, and a lot of supposition and confusion. Consider some of the cutting edge, advanced 0w-30 oils. In general, these will depend in large part upon the characteristics of the base oil to achieve multi-grade characteristics, not so much on polymer VIIs (perhaps not at all). In on instance (GC) also, it appears that the VII used are "exotic" compounds probably not subject to the claimed failings of "polymers" at all (or very little).
This reply is from Terry Dyson who makes a living analysing oil, if you send an oil sample to blackstone labs you pay extra for him to interpret the reading.
Current polymer chemistry is indeed better than in the past but there is a SERIOUS issue currently with aromatics damage of motor oils going unreported by MOST labs in automotive testing. A more shear stable VII and other adds improve resistance to this but it costs a lot to make that kind of motor oil.
Dyson provides prof.lube analysis/consult. NO lube or additive products are marketed.
Oh well...
