Getting My Tranny Replace =D
Old Mar 7, 2007 | 03:38 PM
Richy350Z's Avatar
Richy350Z
Default Getting My Tranny Replace =D
I own a 2003 Nissan 350Z and I am getting my transmission replaced because of 5th & 6th gear grinding and making weird noise. It's getting done on Tuesday , March 13th.
I am just wondering how many miles do I need to put in it to brake it in, before I red line the car? Is it the same as like a new engine? 1,200Miles?
Or it does not need to brake in at all?
Old Mar 7, 2007 | 04:44 PM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
Well it is New!. so it prbly does have to break in a lil bit.. at how many miles? that I do now know...
Old Mar 7, 2007 | 04:48 PM
bigmikewhite6's Avatar
bigmikewhite6
let me no how much thats gonna cost ya cuz mines doin the same thing but with third also
Old Mar 7, 2007 | 05:03 PM
Mid117's Avatar
Mid117
I have an '06, my tranny had to get replaced.
You will feel that the new tranny will be notchy and tight. Give it some time, it will loosen up, and powershift awayyyyy
Old Mar 7, 2007 | 05:33 PM
halfass872's Avatar
halfass872
On my 3rd tranny and every time they said to take it easy for about the first 500 miles or so. But they also said in all reality they are "pre" broken in from the factory so no special attention required. I'd play it safe and drive normal, just don't beat the crap outta it 'till after about 500 miles or so.
Old Mar 7, 2007 | 09:08 PM
QuickAG's Avatar
QuickAG
I had to get my tranny replaced at around 35,000 miles. I swear they should recall that POS. Anyway, I took it easy for a few hundred miles to get all the gears smoothed down. It would be best to avoid friction among brand new, hot expanding metal gears by over-revving. Maybe they pre-broke it in, maybe not. Whatever the case, I'm sure it wasn't pushed to redline at the factory. I say have patience. Like a brand new baseball mit.
Old Mar 7, 2007 | 09:22 PM
norapat01's Avatar
norapat01
how come there're so many issue with the Z transmission? I also wanna watchout for mine.
When you said the transmission is grinding, is it make weird noise after you shift into gear (...you shift, let go of the clutch, the shifter is in the gear that you selected, then it make noises)?
Or, It just make noise during the shift into gear...like when you move the shifter into the gear slot, but it make noise before the shifter is completely in the slot?
I guess the easier way to ask is, what is the symptom of grinding transmission?
Old Mar 7, 2007 | 10:50 PM
Bevo's Avatar
Bevo
I would say go easy on first 1k miles and then you should be good
Old Mar 7, 2007 | 11:21 PM
Korki Buchek's Avatar
Korki Buchek
Every time I try to replace my tranny she, or he, or it gets really upset and looks like it's going to cry.
Old Mar 8, 2007 | 07:01 AM
ZsDaBest's Avatar
ZsDaBest
Just asking out of curiosity? What have you been quoted for the tranny replacement? If you don't mind.
Old Mar 8, 2007 | 08:13 AM
Richy350Z's Avatar
Richy350Z
well it's under my warranty so it's only a $50 deductible
also my right/front wheel bearing is getting replaced...
I got Security Plus (extended warranty)
Old Mar 13, 2007 | 11:56 AM
Richy350Z's Avatar
Richy350Z
My car is at Nissan now =*( ... all getting fixed...
New Transmission
New Wheel Bearing (Right , Front )
New Clutch
New Window Motor
My car is going to feel like new...
After like 2-3 days =( ...
Old Mar 13, 2007 | 12:03 PM
saberphx's Avatar
saberphx
dammit I hope I didn't wait to long to get my tranny replaced, its an 03 and it has 40,xxx miles, with probably a regular warrenty.
Old Mar 13, 2007 | 07:18 PM
mthreat's Avatar
mthreat
New Transmission
New Clutch
New Window Motor
Actually they'll break more things than they fix, and introduce a few new rattles just for good measure! Ah.. love those nissan dealers
Old Mar 14, 2007 | 02:56 AM
Zilvia's Avatar
Zilvia
We had out tranny replaced just under warranty.
5th was grinding. not sure what all they swapped out, but its 05 tranny it think. and the 5th off by a bit. This catch you off guard if you think on it.(so gay)
idk maybe we jut got a bad one but its annoying as hell.
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
