My 03' now has an 07' Tranny
Old Mar 15, 2007 | 07:34 AM
Richy350Z's Avatar
Richy350Z
Default My 03' now has an 07' Tranny
Well like I said bout a week ago ...
https://my350z.com/forum/engine-and-drivetrain/254508-getting-my-tranny-replace-d.html
BUT!
I have a few problems/questions and I want to see if anyone can help?
1.Ok well my red line on the old tranny 03' was 6,500. Does this mean that my redline is now at 7,500? Since I have the complete 07' tranny??
2. When I roll on first gear after 2,500rpm it makes a noise like it's pulling kind of hard , the rest of the gears are fine. Is that because the tranny is brand new???
Please help,
Thanks
Old Mar 15, 2007 | 07:39 AM
gothchick's Avatar
gothchick
1) no, redline is determined (among other things) by how well the engine flywheel, crank, etc are balanced, the amount of reciprocating mass, valve spring strength, intake/ exhaust flow, etc... the tranny will not affect redline.
2) it should be fine, let it break in before hammering it. it should still be under warranty anyway.
PS. Yeah, I'm a girl who just happens to nip out over this ****... :-)
Old Mar 15, 2007 | 12:22 PM
halfass872's Avatar
halfass872
You said girl, and nip in the same sentence ! Was that for attention, cause it will prob work!
Old Mar 15, 2007 | 12:23 PM
halfass872's Avatar
halfass872
https://my350z.com/forum/showthread.php?t=254508
BUT!
Please help,
Thanks
When i got mine (both of em ) I was told to take it easy for the first 500 miles or so.
Old Mar 15, 2007 | 12:29 PM
Motormouth's Avatar
Motormouth
when I got both of mine replaced they said not to take it easy at all.
and the noise you are talkign about.... is it sort of like a farting or crying sound?
Old Mar 15, 2007 | 12:35 PM
Richy350Z's Avatar
Richy350Z
No , it kind of sounds like one of those big trailers taking off ( 1st gear only ) you know how they sound like they're trying so hard to pull all the weight - Which is normal for a huge trailer but I'm wondeing why my Z is makin that noise
Old Mar 15, 2007 | 02:36 PM
halfass872's Avatar
halfass872
It's normal. Try reving up a little more when you start to take your foot off the clutch. Mine does it when creeping into gear in stop and go traffic. Almost sounds like an exhaust brake that big rigs to slow down when they go down hill. At least that's what i always think of.
Old Mar 16, 2007 | 05:51 AM
Alberto's Avatar
Alberto
Cranky FI Owner
What version is your tranny? 008, 009?
Old Mar 16, 2007 | 05:55 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
I'm pretty sure all dealers now are replacing with the 009s.
Old Mar 16, 2007 | 05:57 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Thats not an 07' tranny then, that was a late 05', early 06' tranny. REason I ask is because I had an 008, and put in a 009, and the rear support bracket was different, and it really took a while for the tranny to loosen up on me, was very notchy at first, contrary to what most say about it.
Old Mar 16, 2007 | 05:59 AM
JDMFairladyZ33
Well he got it put in in 07 so it must be an 07 tranny...lol j/k. +1 isn't there an 0010 out?
Old Mar 16, 2007 | 06:08 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Not that I know of, 009 was the last revision. I havent had a chance to check a spec sheet on the 07's gear ratios, but Ive read they may be tighter to account for the 07's higher redline.
Old Mar 16, 2007 | 08:33 AM
Richy350Z's Avatar
Richy350Z
Ok now 2nd day with all this new parts and I've also noticed this,
My Oil PSI sits at around 60 , but when I used to floor the Z it used to go up to 120.
Now when I floor it, it only goes up to like 65 but seems that it runs a bit quicker with all the new parts, but why is it not showing any increase in the Oil PSI gauge??
Old Mar 16, 2007 | 09:40 AM
halfass872's Avatar
halfass872
Hmmmm, oil pressure sending unit maybe?? If so, it's a cheap part and easy to replace.
etkms
Jun 19, 2022 06:30 PM
seagrasser
Oct 11, 2015 03:27 PM
Ace2347
Sep 22, 2015 03:12 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
