thoughts on JWT clutch/ ACT prolight flywheel.
Old Mar 15, 2007 | 08:28 AM
Axelerate's Avatar
Axelerate
Default thoughts on JWT clutch/ ACT prolight flywheel.
I'm looking to upgrade and I have driven a car with a JWT clutch with a Nismo flywheel and I was impressed, but it seems that the ACT prolight is lighter than the JWT flywheel and a little bit cheaper.
Anyone else running this set-up or have opinions?
Thanks!
Old Mar 15, 2007 | 08:30 AM
goodkd's Avatar
goodkd
Thanks!
Do a search - seems like most people say go ACT all the way (clutch and flywheel). I would do this if the install wasn't so expensive (my dealer quoted me $840, but I am trying to find a shop that can do it cheaper).
Old Mar 15, 2007 | 08:32 AM
Axelerate's Avatar
Axelerate
I did and I dont need a heavy duty clutch and I was fine with the cheaper JWT. I wanted to see if anyone had experiances with this particular set-up.
Old Mar 15, 2007 | 08:39 AM
goodkd's Avatar
goodkd
Ok, cool. Good luck. I didn't realize the JWT was signfiicantly cheaper.
Peace
Old Mar 15, 2007 | 08:45 AM
bbs350z's Avatar
bbs350z
yea but whn u start making alot of power, and u have an EXTREMELY light clutch, u lose traction cuz it revs so fast. same concept as putting 3.9 gears in a tt z. makes 1st gear completely useless.
Old Mar 15, 2007 | 08:50 AM
Motormouth's Avatar
Motormouth
I have the ACT prolight. it is great, but chatters really bad after driving it hard. I don't mind sounding like a pickup truck at idle though.
I stayed OEM when i switched though, just upgraded to a 06 spec clutch assembly and SS clutch line.
Old Mar 15, 2007 | 07:08 PM
Axelerate's Avatar
Axelerate
Well, I'm not gonna go FI so I wont be making too much more power.
Would there be any advantage going to the JWT clutch over going with a new OEM one? I know it handles more hp, but I am just running basic bolt-on's.
I do not drag race the car, but I do frequently run track events. I havent had a problem with my current clutch, so maybe I should save some more $$$ and go with a new OEM clutch?
Old Mar 15, 2007 | 07:48 PM
MIAPLAYA's Avatar
MIAPLAYA
I think you'll find the ACT street disc, Stage 1 pressure plate and Prolite Flywheel combo are cheaper then JWT clutch and ACT flywheel combo. I own a ACT clutch and JWT flywheel and if I could do it again I would have waited and gotten all ACT. I've driven a few different setups now and the all ACT setup is my favorite.
Justin100
Nov 25, 2021 06:26 AM
apex locator
Jul 23, 2021 02:27 AM
