VQ Oil Analysis and Info
Old Feb 12, 2008 | 01:42 AM
  #401
350zzzgunnar's Avatar
350zzzgunnar
Originally Posted by Nederlander75
It’s the Viscosity Index Improvers that pose the risk from what I understand and the broader the spread the more there are. A 5w50 is a spread of 45 versus a 15w50 that’s a spread of 35. The 5w50 requires more VI improvers to keep its viscosity at higher temps since its starting from a thinner base stock. Therefore, in my opinion if you are running the 5w50 these VI improvers will be sheared (torn) apart such that you will be sacrificing protection with prolonged use as your 5w50 may end up shearing to below a 40wt. In your application that loss of projection may be detrimental if not destructive on the track or if you are beating on the car. Conversely, I’ve heard that M1 15w50 and others may not contain any VI improvers making them much, much less prone to shear. So, you can get more life out of that oil and be safer on the track. You just need to ask yourself or figure out if you really need 50wt projection in winter. If not you may be able to live with a little shear or a 5w40.
Awesome answer
Thanks!
Old Feb 12, 2008 | 08:17 AM
  #402
Nederlander75's Avatar
Nederlander75
You're welcome
Old Feb 12, 2008 | 01:07 PM
  #403
350zzzgunnar
Guess I'll go for a M1 15w-50 since the car hibernate in the garage during the winter. Or do you have a better suggestion for choice of brand?
Old Feb 13, 2008 | 11:01 AM
  #404
Nederlander75
Im sure M1 will do ok, but there may be other options available that might be better. What brands to you have access to? Fuchs, Amsoil, Shell, Royal Purple, Redline, Motul, Quaker State?
Old Feb 13, 2008 | 11:06 AM
  #405
Mad A's Avatar
Mad A
Quite a few of those brands have been shown to perform pretty poorly in UOA results, Motul and Royal Purple for starters.
Old Feb 13, 2008 | 11:28 AM
  #406
350zzzgunnar
We've got Shell and Redine for shure, the others I've never seen but I'm a oil-retard
Old Feb 13, 2008 | 11:30 AM
  #407
SIR_pierre's Avatar
SIR_pierre
and Shell,QS
Old Feb 13, 2008 | 11:46 AM
  #408
Resolute's Avatar
Resolute
If you guys want to discuss what oils to use for your engines, then start a new thread. This sticky is for posting Used Oil Analysis and discussing the results and trends.
There is another thread in the FI forum where people can give suggestions and opinions on what oils they use in their FI engines.
If you don't have any of the better performing oils available to you in Sweden, then try one you are interested in and post your UOA here to see how well it worked for you.
Will
Old Feb 14, 2008 | 03:32 PM
  #409
tsabrale's Avatar
tsabrale
ima shirimasen
Here you go Will, still may be a little early, but I will post anyhow. Engine seems to be breaking in fine.
Old Feb 29, 2008 | 11:08 AM
  #410
IP05G35's Avatar
IP05G35
Be on the lookout for my UOA pretty soon on my G35 running Mobil 1 0w-40 for ~8000 miles.
Old Mar 1, 2008 | 08:19 AM
  #411
Nismospeed4life's Avatar
Nismospeed4life
I can't wait to see your results, since I am running the same on my Z.
Old Mar 1, 2008 | 09:11 AM
  #412
ZeeForce's Avatar
ZeeForce
^^ Ditto on that...I am also running Mobil1 0w-40 on my 05, but only have 4135mi...oh wait, it's time to change oil soon. My plan was to change it at 4400mi. Thanks for the reminder.
Old Mar 1, 2008 | 10:58 AM
  #413
Nismospeed4life
How's it going ZeeForce, I have not talk to you in a while. I've notice that I am also consuming less oil with Mobil 1 0W-40. Way less than when I was running Amsoils 5W-30.
Old Mar 2, 2008 | 08:06 AM
  #414
Resolute's Avatar
Resolute
A couple of guys have wondered where my Rotella T-Syn report is. I am still running this oil. I'll get it analyzed in a month or so, which means it will have been in service for about a year, but only 5k miles.
Nederlander75 asked a question about the base stock that Shell uses in their T-Syn, which is a slack-wax base stock derivative. It's also known as Shell's XHVI base stock, and is used in other formulas of oil, such as their Helix Ultra.
Shell's XHVI base stock, which is a Group III oil, is made by the hydroisomerization of slack wax, as opposed to most other Group IIIs, which are hydrocracked crude. Slack Wax is a byproduct that is formed from a solvent process, but what Shell uses is a synthetic slack wax feedstock made from the Fischer-Tropsch method. The Fischer-Tropsch method is how the very first synthetics were made, and is the method behind Gas-to-Liquid (GTL) base oils as well. So, Shell's XHVI base oil is made from the hydroisomerization of their synthetic slack wax which is developed through the Fischer-Tropsch process.
Slack Wax oils have a VI of >140 and perform similar to a PAO in almost every way. Cold Pour Point is about the only area where common PAO's have a meaningful edge- about 10 degrees lower on average.
Will
edit: broke into paragraphs for easier reading
Old Mar 2, 2008 | 08:18 AM
  #415
Mike Wazowski's Avatar
Mike Wazowski
Will, what do you think about what he is saying here?
Originally Posted by JETPILOT
With respect to the MOTUL UOA reading high in lead... if you run leaded race gas your going to contaminate your oil with lead. I think Quad ran race gas when he was using the MOTUL. As far as iron... I imagine that is from the cams. Why? I have no idea. Aluminum.... that has to come from the head/valvetrain I imagine.
I am going to be using MOTUL in a few weeks after my motor is broken in and I will send it to Blackstone to get an UOA.
I don't think we can draw any conclusions about MOTUL yet. There are just not enough UAO's. BUT the series 300 racing oils exceed the standard for API-SH which indicates a very high level of ZDDP.
ZDDP which is an anti wear additive (zinc and phosphorus) has been reduced in newer oils because of it's ability to contaminate catalytic converters. You can find high levels of these additives in API SG-SJ with the minimum rating used being SL rated oils. So the oils falling under these classifications are likely the best to use for reduced wear although having short drain intervals (3000-5000mi).
Since extended drain intervals are not what we are looking for in an oil we should consider sticking with API SE-SJ rated oils instead of API SM or SL/AEPA CJ-4 rated oils.
API SJ rated oil meet the new ACEA A3/B3 European requirments for acceptable wear during testing which is approx 1/4 the wear allowed with the new API SM or CJ-4 oils (Rotella T). Rotella T is now an API CJ-4 oil and the additive package in this oil seems better suited to keeping emissions controls happy than to protecting the engine. Rotella T was a CI-4 oil, but has been reformulated as a CJ-4 oil and the addative package is not as good. If you can find the CI-4 then stock up on it.
Another great oil is the Amsoil Series 3000 diesel oil. It has high amounts of ZDDP and is API SH/CI-4 approved.
Our owners manuals state to use API SG/SH/SJ/SL. We should not stray from these designations/addative packages since that's what the bearings, valvertrain etc. were designed for.
Here is a great article about the changes in additive packages mainly concerning ZDDP. These changes are being fueled by tighter EPA restrictions not to the benefit or the longevity of your engine.
http://www.lubrizol.com/press-room/m...ate+Thickeners
JET
link
https://my350z.com/forum/forced-induction/323131-built-motors-what-oil-filter-are-you-using-2.html
Old Mar 2, 2008 | 08:38 AM
  #416
Resolute's Avatar
Resolute
I'll respond in that thread when I have time. There's some info that's wrong, and some assumptions that I don't agree with, but I understand what he was trying to say. Not sure if it's worth arguing about the significance of API certifications for stock engines in a thread about built FI engines, though.
Motul does use a lot of ZDDP, but high levels of ZDDP is not indicative of anything any more than base stock alone is. I could post several SAE papers about Borate Esters (boron) and Antimony being much better anti-wear additives than ZDDP, but one aspect alone does not make a great oil. If that was the case, then Motul might actually be worth the money, but as it is, despite the use of esters and high amounts of ZDDP & Moly, the UOA's still suck when compared to another oil run in the same engine. Oil is a product of all its parts, and no single aspect alone determines the oil's performance.
Will
Old Mar 2, 2008 | 01:21 PM
  #417
IP05G35's Avatar
IP05G35
I went to change my oil yesterday but I realized I didn't have any more kits from Blackstone... sorry guys no UOA for the Mobil 1 0w-40 from me. I put in Amsoil ASL 5w-30 this time. I also replaced my K&N panel filter with an Amsoil nanofiber panel.
Old Mar 3, 2008 | 12:12 AM
  #418
Nederlander75
Will
Thank you very much. Ive got some of the newest Rotella T syn 5w40 Im going to get a VOA on. Stuff smells like gear oil now.
Old Mar 8, 2008 | 10:05 PM
  #419
Teufel's Avatar
Teufel
Using 0W-40 M1
Going to 0W-30 German Castrol in 2K miles
Purchased Amsoil Nano Fiber
Old Mar 17, 2008 | 11:29 AM
  #420
bwassul's Avatar
bwassul
Default Wear issue?
Okay, guys. Will asked me to post this up so you can have a look at it. I have a 2005 G35 coupe 5AT daily driver with 30k miles (no tracking or >4k rpms). She was broken in with conventional oil before going synthetic. This is the UOA from my most recent change on German Castrol; the previous changes were M1 5W-30 EP and M1 5W-30. I am not F/I. You can see that bearing wear (lead, copper) has been a lot higher, almost double, the universal averages. My aluminum wear has been average or higher, but I'm attributing that to city driving. I'm currently running M1 0W-40. Any thoughts on the bearing wear issue?
