Crank pulley fugged up!
Old Apr 2, 2007 | 04:51 AM
  #41
westpak's Avatar
westpak
SFZCC
Originally Posted by MRC Motorsports
.......done by a shop in Michigan.The guy purchased the car used, from a guy in Michigan who had the car done there at a half assed shop (Not GRD, and Not Charles's shop) ........
That is good to know but they are both in Illinois last time I checked.
Old Apr 2, 2007 | 04:56 AM
  #42
Julian@MRC's Avatar
Julian@MRC
Michigan Area..Sorry, my bad....
Old Apr 12, 2007 | 05:42 PM
  #43
G352NV's Avatar
G352NV
Ok guys sorry for the delay. I pulled the trans at the same time and sent it out to be rebuilt. Trans came in and I put everything back together. Started it up and VROOM!!! Its all good!!! Thanks guys for those who replied and helped with parts.
Old Apr 12, 2007 | 05:59 PM
  #44
ktown z's Avatar
ktown z
sorry to hijack but will a generic aluminum crank pulley that is tighten to spec be fine or will it cause a leak?
Old Apr 12, 2007 | 06:04 PM
  #45
Ztalker's Avatar
Ztalker
how generic is the pulley?
Old Apr 12, 2007 | 06:08 PM
  #46
G352NV's Avatar
G352NV
Heres what I would do with ANY pulley thats been replaced. Make sure the crank bolt has red loc tite on it. Re TQ it after 1000 miles. If you do these things I dont think you'll have any problems.
Old Apr 12, 2007 | 06:09 PM
  #47
Eazzy's Avatar
Eazzy
Ya? Did it come in a tin can with a White label and Black lettering ?
Old Apr 12, 2007 | 06:12 PM
  #48
Eazzy's Avatar
Eazzy
Seriously --True, and if it didnt already have one, I would Speedi-Sleeve it
Old Apr 13, 2007 | 01:30 PM
  #49
ktown z's Avatar
ktown z
I was talking about the generic all aluminum ones for sale on ebay and other shops. I have a custom stock sized aluminum crank pulley made by ASP that does't have a sleeve. I bought it when i had a procharger and haven't removed it.
Old Apr 13, 2007 | 06:02 PM
  #50
Eazzy's Avatar
Eazzy
Its your call---APS is fine til it leaks , then sleeve it. As far as the one on E-Bay, like I said, its your call
Old Apr 27, 2007 | 06:17 AM
  #51
three_fitty's Avatar
three_fitty
Ok yep its a UR.
I'm installing my UR pulley tonight. But i've noticed on your picture, the key way is completly different. Mine is just a notch straight through.
Old Apr 27, 2007 | 06:23 AM
  #52
Eazzy's Avatar
Eazzy
Matters not, Important thing is your key is in perfect condition and fits tite
Old Apr 28, 2007 | 07:14 AM
  #53
Cube's Avatar
Cube
CNR pulley with grooves in the aluminum b/c no steel sleeve. This is probably where yours is heading... although I had a CNR on mine for several months without an oil leak. I did, however, have these grooves on it when I took it off.
So like Eazzzzzzy said, it'll be fine until the grooves eventually cause it to leak, then sleeve it (or sleeve it now) and it'll be fine.
Old Apr 28, 2007 | 07:22 AM
  #54
Eazzy's Avatar
Eazzy
My way of thinking is--- If you buy it new and it is not sleeved, sleeve it. There are times on a new product, I will go so far as Heli-Coiling potential trouble spots before the trouble starts
Old Apr 28, 2007 | 09:25 AM
  #55
Cube's Avatar
Cube
Is that Heli-Coiling?
Old Apr 28, 2007 | 10:18 AM
  #56
Eazzy's Avatar
Eazzy
No --- Thats my Aunt Jasmine actin the fool. Thats no more a Helicoil than a Paralegal is an attorney in a wheelchair.
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
