NA 272cams or bigger *IDLE*
Old Apr 9, 2007 | 09:19 PM
DET_Monster's Avatar
DET_Monster
Default NA 272cams or bigger *IDLE*
just wondering how the idle is on larger duration cams. any info on drivability, etc.
would be tuned with emanage ult. BTW
Old Apr 9, 2007 | 09:33 PM
Justin@WestCovinaNissan's Avatar
Larger duration typically bring about rougher idle, however a good tune can typically smooth it out a bit
what other mods do you have and what are your future plans?
Old Apr 9, 2007 | 09:56 PM
97supratt's Avatar
97supratt
272's usually have idle fluctuations without any sort of tune. 264's should be okay.
Old Apr 9, 2007 | 10:40 PM
Machupo's Avatar
Machupo
i have the tomei 268's and the car would stall out at the normal idle. Bumped it to 1000rpm and its still lopey, but it doesn't stall out. Actually, the lopey sound + tp's and nismo exhaust definitely turn heads around here, hahaha.
Old Apr 10, 2007 | 04:18 AM
EM-EFER's Avatar
EM-EFER
I bumped my idle to 1200 RPM with the 268's and it is still loopey as well.
Old Apr 10, 2007 | 05:40 AM
QuadCam's Avatar
QuadCam
check the duration at .050" valve lift. That is far more important than "advertised duration."
you might have 2 cams with the same "advertised" duration of 262, but one may have lazy ramps, while the other has very aggressive ramps. At .050" lift, there may be a 5 degree difference in the duration! also, there isn't an appreciable amount of flow below .050" either.
Old Apr 10, 2007 | 06:11 AM
rednezz's Avatar
rednezz
On 272 intake and exhaust from Tomei the car won't really idle at 750 rpm but it will at 1000 rpm with a nice sounding lope.
Old Apr 10, 2007 | 06:45 AM
ke0ki2k's Avatar
ke0ki2k
where can you buy 272 Tomei cams? what all do you need other than valve springs?
Old Apr 10, 2007 | 09:30 AM
rednezz's Avatar
rednezz
I bought the cams from Sharif@Forged Performance. I assume you will need new valve springs if you utilize the full power band of the cams. However, I am not 100% positive because I used the valve train that came with the Cosworth heads.
Old Apr 10, 2007 | 10:12 AM
DET_Monster
anyone had any success in helping the idle by tuning?
416blueZ
Jun 11, 2024 10:56 AM
seagrasser
Oct 11, 2015 03:27 PM
416blueZ
Sep 24, 2015 02:11 PM
