350evo 3.9 and Central 20 3.9 ????
Old Apr 18, 2007 | 09:52 AM
bhori's Avatar
bhori
Default 350evo 3.9 and Central 20 3.9 ????
whats the diff from these two 3.9 FD gears? its bout 400 diff thats alot hehe.. anyone thnks.... btw anyone heard of Kaaz they are a LSD and Diff specialist... thnks again.
Old Apr 18, 2007 | 09:58 AM
bbs350z's Avatar
bbs350z
no difference except the price. central 20 makes good products despite being cheaper. as 4 the diff. wutever u do, dont get a full open, ul regret it if its ur dd.
Old Apr 18, 2007 | 10:33 AM
bhori's Avatar
bhori
whats ull open? and DD? thnks again.
Old Apr 18, 2007 | 11:57 AM
bbs350z's Avatar
bbs350z
full open is a 2way diff. its strictly 4 the track, and itll cause u hell on ur daily driver (dd)
Old Apr 18, 2007 | 11:59 AM
bhori's Avatar
bhori
thank ya i will keep that in mind!
Old Apr 30, 2007 | 06:57 PM
zmedic16's Avatar
zmedic16
why would a full open lsd 2.way would suck as a dd???
Old Apr 30, 2007 | 08:02 PM
Armitage's Avatar
Armitage
I'm not sure myself, but I've heard the best option to go with is the 1.5. It has to do with how the LSD works.
Old Apr 30, 2007 | 08:08 PM
Sunset350ZR's Avatar
Sunset350ZR
How much if any can the 3.9 gears decrease the 0-60 or quarter mile time? In other words what are the benefits in this to counter higher gas cost with gears?
Old Apr 30, 2007 | 08:53 PM
Armitage's Avatar
Armitage
The 3.9 gears give you about a 10% boost in acceleration in each gear. As such, your will lose a little bit of time off your 1/4 mile and 0-60. However, you lose some MPG when cruising because your revving higher in each gear now and you will lose some top speed (maybe 2-3 mph).
Old Apr 30, 2007 | 08:54 PM
plumpzz's Avatar
plumpzz
the 2 way will lock on acceleration and deceleration, if i understand correctly.
Old May 1, 2007 | 03:21 PM
WhiteOnWhite350z's Avatar
WhiteOnWhite350z
so u lose 1/4 time,0-60 and gas as well???
Old May 1, 2007 | 04:26 PM
gotbooost's Avatar
gotbooost
yup. you can get around .3-.4ish off your et. i started hitting fuel cut in 4th though.. technosquare ecu is coming tomorrow.
Old May 3, 2007 | 04:37 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
there is no fuel cut on a Z...you hit the rev limiter
my car lost 0 gas mileage
Old May 3, 2007 | 10:23 AM
gotbooost's Avatar
gotbooost
so does the z rev limiter cut the ignition? how does it stop the motor from revving higher?
it felt pretty nasty when i hit the hard limiter
Old May 3, 2007 | 10:26 AM
Z1 Performance
Former Sponsor
it's encoded into the ecu
a reflash, or a utec, can be used to raise the rev limiter
fuel cut happens when you've max'd out the mass air sensor
Old May 3, 2007 | 11:16 AM
losangelesZ's Avatar
losangelesZ
You're mixed up, a 2-way is a diff that locks under decel and accel. An open diff only sends power through the path of least resistance, i.e. the wheel that has the least amount of traction. A 2 way would actually be considered almost fully locked, which is impractical for daily driving. An open diff however is fine for dd but not for performance driving where power needs to be transfered to the tire/tires with the most grip.
Old May 3, 2007 | 11:19 AM
LG_z33's Avatar
LG_z33
exactly.
Old May 3, 2007 | 03:50 PM
ke0ki2k's Avatar
ke0ki2k
1.5 way under 60% lock is bearable for DD but still has great performance gains. 2 way is a PITA apparently for DD or a 1.5 way under like 80-100% lock sucks DD too. Get the Nismo 1.5 way and the central 20 3.9 fd, 350evo is dying, you might never get your stuff.
Old May 3, 2007 | 04:14 PM
gotbooost's Avatar
gotbooost
So doesn't the ECU have to cut something (either ignition or fuel) to stop the motor from revving higher?
I'm trying to understand how the stock 350z ecu can stop the motor from revving past a certain point without cutting fuel. Felt like fuel cut to me.
Sunset350ZR
Nov 15, 2015 05:45 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
dwnshift
Nov 10, 2006 02:04 PM
valuetl
Jan 30, 2003 08:35 PM
