Pleas Help Car Wont Start Now.
Old Apr 21, 2007 | 02:47 PM
scshay's Avatar
scshay
Default Pleas Help Car Wont Start Now.
hey every one i just got my car tuned o 2 days ago we rased the timeing a little and made it run a bit leaner
and i achived good numbers 370 whp and 315 wtq on the vortech kit.
after we did that we reset the ecu i belive we just diconeced the battery for 2 min. then pluged it back in the then re dynoed the car made the same #S
i left the shop most of my lights wher on the dash but after 1 min of driveing they all went off i figured low batery. the car ran great for a cupple days and now. 2 days later my car wont start
it ran great for the first cupple days then today i went out to start it and my remote wouldnt open the doors.
so i though the batery was dead, so i opend it with my key went to start the car and it fired up, but then died right away tryed it again and same thing happend?
seems like its not geting fuel or something but i know its not the batery cause the radeo and everything worked?
is it just a coincedence that my remote door opener dosnt work either?
any one have any ideas??
Old Apr 21, 2007 | 02:53 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
getting any check engine light?
Please tell me english is not your first language. If it is, then
Old Apr 21, 2007 | 04:08 PM
hwcustoms's Avatar
hwcustoms
Is the fuel pump fuse good?
Old Apr 21, 2007 | 04:39 PM
scshay's Avatar
scshay
im thinking it may be something with the fuel aswell i hope its just the fuse.
as far as i know the fuel pump should be good.
Old Apr 23, 2007 | 03:15 PM
scshay's Avatar
scshay
no check lights at all
but it wont start so i cant tell what lights im geting and if its the fuel pump how dose the explain the power windows and locks and trunk not working?
Old Apr 24, 2007 | 06:20 PM
mgtibbetts's Avatar
mgtibbetts
check each and every fuse. if you have a fuel management computer (FMU)for your vortech kit it might be on a 12V switched power source or it might have a connection to one in order to turn itself on. If the FMU isn't turning on your fuel pump possibly is not turning on either. Start by checking the fuses behind the battery in the engine compartment. I've had this problem before.
Old Apr 26, 2007 | 06:43 AM
scshay's Avatar
scshay
we found the problem it was the bcm
(body control module)
now will i need to retune?
aarrgghh
May 1, 2022 11:04 AM
Ronso
Oct 30, 2015 12:39 PM
Mattg350z
Oct 2, 2015 06:51 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
