Convert 04 non-rev engine to dual intake like 07
Originally Posted by Wired 24/7
For all intents and purposes, the answer is no.
1. 07 Plenum etc won't fit on 03-06
2. You have no way to control dual throttle bodies/MAF sensors
2)What if you use 07 ECU which utilizes dual MAF?
It's doubtful to be possible without a ton of custom work. Again because of the ECU issue, as well as the wiring harnesses. The wiring harness for 07 is majorly different. There is also the vehicle security feature on the ECU that prevents ECUs from being swapped from one car to another. It would be way cheaper to sell whatever Z you have and buy an 07. By many thousands of dollars.
Of course, if you want to give it a shot, go for it, I won't stop you.
yes - if you also get the wiring harness, and ecu, new accessories, etc then you can swap the motor in. Break out the black card for that swap
there are almost no similarities between old and new motors aside than they both came from Nissan and are both 3.5 liter V6's
At the point where you are swapping a motor in, you mind as well just buy the 07
here's a link to a previous discussion, less than a week ago BTW.
https://my350z.com/forum/engine-and-drivetrain/265673-07-hr-motor-swap.html
You can get all those parts from a clip
Just wait for someone extremely careless and/or female (
) to get the back half of his (or most likely her
) '07 HR split right off and buy the clip
Originally Posted by failsafe306
Sexist
look like something a guy would try to do???
Can we see what Tim @ SFR has in store for us without calling?
...*cough*
This is all I found from searching... some extremely useful info on plenums.
https://my350z.com/forum/showthread....fr+dual+plenum
Was not that hard to find....
https://my350z.com/forum/forced-induction/258490-new-pics-of-sfr-twin-plenum-twin-tb-twin-maf-twin-bov.html
Originally Posted by meatbag
I was sooo trying to NOT open that can of worms in this thread, but yeah. That is pretty much the only "dual intake" that's sort-of available in theory for the 03-06
How much does that monstrosity run again??
