very bad hesitation....
Old May 19, 2007 | 09:06 AM
cracka350z's Avatar
cracka350z
Default very bad hesitation....
i seem to be getting some really bad hesitation lately. 1st gear feels ok but once i get into 2nd and above it feels really laggy. sounds a little like its struggling. i am throwing a code for my o2 sensors but i have tp on the car and didnt think it would be a problem. any suggestions? could it be the plugs maybe? or should i buy some non foulers?
Old May 19, 2007 | 11:35 AM
IIQuickSilverII's Avatar
IIQuickSilverII
check vaccum leaks
CHECK what the code says...
o2 sensors testpipes code shoudl not cause the engine to behave liek this though
Old May 19, 2007 | 12:18 PM
cracka350z's Avatar
cracka350z
did check the codes...bad o2 bank and whatever. ive seen the codes before and they have been there the whold time with no problems. it feels like there is some misfiring. basically lately there is no power before 3k rpms. and im getting a bad gas/oil smell. damn i miss warranty.
Old May 22, 2007 | 12:09 PM
cracka350z's Avatar
cracka350z
bump
Old May 22, 2007 | 01:06 PM
hwcustoms's Avatar
hwcustoms
Do any really hard driving before this started? Have you had a compression test lately? How many miles are on the car?
Old May 22, 2007 | 01:49 PM
cracka350z's Avatar
cracka350z
90,XXX miles, its bad right from the start up. like when i take off from a light, (normal) it revs all slow and laggy... As far as a compression test, not lately. been a little broke and it sux. but as im driving if i punch it, i can feel it kind of bucking. very lightly but i can feel it.
Old May 22, 2007 | 01:51 PM
IIQuickSilverII
check your hoses man... make sure you got no vaccum leak...
then also do a compresion test if all the rest checks out...
Old May 22, 2007 | 01:55 PM
ohSIXz's Avatar
ohSIXz
fuel injectors? my car felt like it had MAYBE 30hp. took me a few minutes to get to 20mph full throttle.
my fuel injectors were clogged. 19k miles. total crap.
Old May 22, 2007 | 02:31 PM
VO...'s Avatar
VO...
Administrator
Perhaps a bad batch of gas or fuel filter related.
Old May 22, 2007 | 02:40 PM
CG350z's Avatar
CG350z
How hard is it to change your own fuel filter?
Old May 22, 2007 | 02:42 PM
VO...'s Avatar
VO...
Administrator
I haven't had to replace the one on my car as of yet, but have done plenty on other vehicles. It's fairly simple though. A few hand tools and some rags.
Old May 22, 2007 | 02:45 PM
cracka350z's Avatar
cracka350z
and one of the O rings...(that rubber thingy) i did it on my spec V and didnt get one and had to ghetto rig it. it wont fit back after...
ill check the hoses and stuff. another thing is the car itself sounds a bit louder. like the intake and exhaust is more throaty for some reason. ( i have a popcharger, test pipes and a y pipe and its changed a good bit since installation ((and i know its not just breakin))) im just keeping my fingers crossed that there is a cheap way of taking care of this.
Old May 22, 2007 | 02:49 PM
VO...'s Avatar
VO...
Administrator
some cars use brass O-rings also. My old Eclipse did.
I think the noise thing might just be your mind playing tricks on you. I'd address the hesitation issue. Keep us posted.
Old May 22, 2007 | 02:56 PM
cracka350z's Avatar
cracka350z
no bad gas....filled up like 5-6 times since it started...
Old May 22, 2007 | 02:58 PM
VO...'s Avatar
VO...
Administrator
I'd hit that filter up then, especially with 90k miles on it....
Could be the plugs also, but I'd imagine the filter would be the lesser of 2 evils.
Old May 24, 2007 | 11:07 AM
Dave B's Avatar
Dave B
The fuel filter on VQ35 is a non-serviceable piece. It's built into the fuel pump. I suggest hooking the motor up to a vacuum gauge to verify you don't have a vacuum leak. It's a simple and cheap test.
Old May 24, 2007 | 11:38 AM
VO...'s Avatar
VO...
Administrator
Good info to know. I was unaware of this, being I've never had to pull the pump or filter on the Z as of yet.
Old May 24, 2007 | 11:43 AM
IIQuickSilverII
+1 good call... i have been talling him already i have a feeling it could be a vaccum leak
Old May 24, 2007 | 03:57 PM
cracka350z's Avatar
cracka350z
trust me...i hope its as easy as just a hose. after 90k should i be replacing hoses anyways? im throwin new plugs in there anyways just for S & G. and the noise thing is not just me tho...my girl noticed it too. (before i said anything to her.)
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
