gray smoke......
Old May 24, 2007 | 07:22 AM
Changvi's Avatar
Changvi
Default gray smoke......
Ok, here it goes. yesterday, i added aditional a half quart of engine oil to my motor. Upon checking the dip stick, the line was above H. So this morning, i got some gas and proceeded to work as usual. All of the sudden, i see these grayish smoke coming from my pipe. Since this has happened before, i wasn't too concern about it. But the smoke kept on coming back upon acceleration and deceleration. Then it would go away, and then come back. So i figured maybe because i was running rich or something. As i was on my way home from work, the smoke came back, but not as bad. so i figured maybe i should reset my ecu to see if this would cure the problem. After the reset, the smoke seemed to disappear. i then i tokk the car for a test drive. There was still a small amount of grayish looking smoke, but not as bad as before....this was while sitting at a stop light. All of the sudden some smoke appeared underneath my car, which it seemed to come from either the TP or headers. I was like WTF? Ever since, the smoke just went away adn never came back. I asked my buddy, and he told me that it could be due to excess oil, and the engine burned off the excess oil. What do you guys think? Any thoughts would be appreciated.
FYI my car is NA with plenum,TP, HKS TI, Strup headers. Unichip tune, and JWT intake
Old May 24, 2007 | 08:22 AM
97supratt's Avatar
97supratt
If you topped off your oil and went over the full line then yes you will burn it off. It will eventually go away by burning off. If you saw smoke from the bottom of the car and you are sure your engine doesn't have a oil leak, then you might have a exhaust leak.
It's nothing to worry about, it'll burn off so you're okay.
Old May 24, 2007 | 08:28 AM
Changvi's Avatar
Changvi
Thank you for your input....I thought there might be a bad seal or something.
Old May 24, 2007 | 08:31 AM
97supratt's Avatar
97supratt
Usually if you have a bad seal or a leak, you will have consistant smoke. If you saw it die down, then you should be okay.
Old May 24, 2007 | 09:03 AM
Bevo's Avatar
Bevo
I would check the dip stick again to make sure
Old May 24, 2007 | 09:21 AM
Changvi's Avatar
Changvi
Yup, nothing from this morning. Not a sign of smoke at all. I checked the dip stick yesterday and it was above H mark.
Old May 24, 2007 | 04:23 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Why did you add the oil?
Sounds like you definitely overfilled... so that begs the question -- why would you add oil when you don't need to?
Old May 24, 2007 | 10:42 PM
Changvi's Avatar
Changvi
I have no idea. Just wanted a bit more protection. But, i guess poured a bit too much. By the way, the smoke came back again. Checked the oil level, still way above H mark. Getting an oil change tomorrow to see if the smoke would disappear.
Old May 24, 2007 | 11:01 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
That should do it, you definitely overfilled.
Science usually goes... if you change one variable, and then you get a problem...it was probably the change that caused it
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Shift_Speed
Apr 5, 2006 10:27 AM
Blue Liquid
Dec 9, 2003 12:54 PM
tyoung88
Oct 27, 2003 06:06 PM
dchengmd
Oct 15, 2003 01:17 PM
