TT throws vdc off and slip light?
Old May 31, 2007 | 09:52 PM
Abishop's Avatar
Abishop
Default TT throws vdc off and slip light?
well finally got my car back today and I'm very happy but i still need to work out the bugs. I have a problem....
My car throws a VDC off light and a SLIP light every time i start the car. It didn't do this before my TT were installed. Anyone know why this is happening? Anyone know a fix for this? Is it common?
Old May 31, 2007 | 09:54 PM
redman333's Avatar
redman333
You should be happy, every time I get in my car I turn off my vdc. I wish it would stay off.
Old May 31, 2007 | 09:59 PM
r0mey's Avatar
r0mey
leave it off
Old May 31, 2007 | 10:06 PM
Abishop's Avatar
Abishop
Ok, this isn't normal right? And what about the SLIP light?
Old May 31, 2007 | 10:14 PM
redman333's Avatar
redman333
No its not normmal. My vdc comes on when I do donuts and the slip light stays on along with the vdc off light.
Old May 31, 2007 | 10:18 PM
Abishop's Avatar
Abishop
yea, see it will come on with out me doing anything to set it off...
Old May 31, 2007 | 11:14 PM
Abishop's Avatar
Abishop
My steering wheel is off now since they pulled the steering rack. i wonder if this is the fix..... https://my350z.com/forum/showthread....ght=SLIP+light
Old Jun 1, 2007 | 01:26 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Take it back to Eric and have him fix everything.
Old Jun 1, 2007 | 06:14 AM
denverinfiniti's Avatar
denverinfiniti
Check your brake fluid. We have G's come in all the time with the those lights on. Its usually from low brake fluid levels.
Old Jun 1, 2007 | 06:26 AM
tyrone coupe's Avatar
tyrone coupe
had the same problem when the APS TT was installed on my car.
The steering arm was put on 180 degrees wrong.
had the agents reset it and no problems since.
Though have not physically turned the arm aroung 180 degrees
Hope this helps
Old Jun 1, 2007 | 06:53 AM
Abishop's Avatar
Abishop
Hope this helps
Thank you for you help!
Old Jun 1, 2007 | 07:02 AM
Aced16's Avatar
Aced16
+1! happen to me, make sure its filled with plenty of fluid.
Old Jun 1, 2007 | 07:06 AM
westpak's Avatar
westpak
SFZCC
More than likely they installed the steering shaft in a few teeth off from where it was, the best way is for them to take it out and put it where it is supposed to be, other option is to have the dealer rest the steering angle but that will leave you with a steering wheel not straight, the car will be fine and lights off but crooked steering wheel.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
