Nismo Power Steering Cooler--pix.
Old Jun 4, 2007 | 01:27 PM
jonnylaw's Avatar
jonnylaw
Default Nismo Power Steering Cooler--pix.
Just got a nismo power steering cooler for the vq35DE--it is marketed for the 350z, but was hoping it could fit my g coupe. What do you guys think. Here are some pix:
Old Jun 4, 2007 | 01:35 PM
97supratt's Avatar
97supratt
Do you have larger than stock wheels or wider tires?
Old Jun 4, 2007 | 01:46 PM
jonnylaw's Avatar
jonnylaw
Stock oem 19's w/ stock potenzas.
Old Jun 4, 2007 | 01:49 PM
Kwame's Avatar
Kwame
I feel like I know where this is headed...
Old Jun 4, 2007 | 01:54 PM
Mr_Drifter's Avatar
Mr_Drifter
what if he does?
Old Jun 4, 2007 | 02:18 PM
97supratt's Avatar
97supratt
Originally Posted by Mr_Drifter
what if he does?
It's the only reason why you would need a aftermarket power steering cooler. The stock one works fine for the OEM wheel/tire combination. The aftermarket ones are used for bigger wheels, wider tires because the power steering pump gets overworked.
Old Jun 4, 2007 | 02:19 PM
97supratt's Avatar
97supratt
lol Please tell me i'm wrong.
Old Jun 4, 2007 | 03:21 PM
jonnylaw's Avatar
jonnylaw
Wouldn't the stock power steering pump possibly get overworked no matter what size wheel/tire combination after high flogging on autoX or the like?
Old Jun 4, 2007 | 03:27 PM
ke0ki2k's Avatar
ke0ki2k
im runnin 265/40s up front, think a powersteering cooler is necessary/good idea?
Old Jun 4, 2007 | 04:09 PM
Kwame's Avatar
Kwame
It's not that your wrong, but I would say that 99% of Z owners don't need this mod period. Not to mention its a messy install.
Don't get me wrong, I am running 265/35/19 Michelin PS2s on 19 x 9.5 +12 Volk TE37s up front and I bought the nismo power steering cooler not because I needed it, but because I am a lunatic and I like buying parts that I don't need just because.
Oversized tires or not this is not a necessary mod unless its for a really serious track car operated in a hot weather climate, which in that case the car would not be using larger than stock wheels.
Old Jun 4, 2007 | 05:14 PM
97supratt's Avatar
97supratt
+1 couldnt agree more.
Old Jun 4, 2007 | 05:50 PM
Lawn Dart's Avatar
Lawn Dart
LOL - this thread is classic.
How dare you waste $125.
Seriously, from what i've read, the Nismo power steering cooler would be desireable for people that maintain high RPM's. Therefore, the power steering pump will compress fluid at a high rate then it was designed for which creates much more heat. Not how much you wack your 20 inch wheels left or right.
Did I hear wrong?
Old Jun 4, 2007 | 06:41 PM
jonnylaw's Avatar
jonnylaw
What's messy about the install?
Old Jun 4, 2007 | 07:22 PM
MIAPLAYA's Avatar
MIAPLAYA
The simple answer is yes it will work on the G35. You will probably need to play with the mounts a little bit to get it to work right. Me and friend messed with the mounts and got it mounted off the Spearco intercooler fan shroud mounting bolts which positioned it right in the passenger side air inlet vent of the stock bumper..
Old Jun 4, 2007 | 07:27 PM
97supratt's Avatar
97supratt
Did I hear wrong?
I'll remember that next time I run my car at 7500rpm for 5 days. lol
This is only true if the pulley has been changed to a smaller unit. The OEM unit is made for that engine which in fact can rev that high. I think if you are running such high rpm's your motor might blow, or your coolant might boil before that power steering pump fails.
Old Jun 4, 2007 | 08:06 PM
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by MIAPLAYA
The simple answer is yes it will work on the G35. .
Old Jun 5, 2007 | 04:44 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Actually PS coolers are nice for autoX or drifting, any event where you abuse your steering rack. I've even heard of people boiling their PS fluid while drifting, so a cooler definitely can't hurt
Old Jun 5, 2007 | 11:54 AM
jonnylaw's Avatar
jonnylaw
I'm gonna try to make it fit next monday, when I put in my arc radiator--I'll let you all know how it turns out.
Old Jun 5, 2007 | 11:58 AM
iStan's Avatar
iStan
ZR
Arc Radiator? The Nismo PS cooler probably wasn't a blip in the scope of things. haha
Old Jun 5, 2007 | 01:58 PM
jonnylaw's Avatar
jonnylaw
^^I'm a sucker for ARC products and other JDM parts that give no better gains than products readily available in the States for 1/2 the price
Power Enterprise Cats on the way too
