Happy day. pix.
Look at all this stuff that usps dropped off for me today
--currently being installed: Power Enterprise HFC (400 cell mettallic core); ARC super micro conditioner radiator, thermostat, pressure cap, oil cap, upgraded oil pan; Varis carbon fiber engine cover; TSquare flashed ecu; Iridium plugs; Samco hoses
Took some sound clip recordings w/ a digital cam. Still breaking in my clutch/flywheel, so I didn't push it too hard. The cam was sitting in the passenger seat (so its louder outside the car
). If u listen for the one clip on the highway, u can hear a bike that flew by me. lol
Still have OEM exahust from y-pipe back, but the breathing mods so far are: MD 5/16 iso spacer, MREV2, Amuse Titan intake pipe and Nismo filter, Nismo jet-hot treated headers, Power Enterprise mettalic HFC.
https://home.comcast.net/~jofficer1/Medium_run.wav
https://home.comcast.net/~jofficer1/Small_run.wav
https://home.comcast.net/~jofficer1/Small_run_2.wav
https://home.comcast.net/~jofficer1/Small_run_3.wav
https://home.comcast.net/~jofficer1/Slow_run.wav
https://home.comcast.net/~jofficer1/Slow_to_stop.wav
https://home.comcast.net/~jofficer1/Highway_run.wav
https://home.comcast.net/~jofficer1/Blip.wav
https://home.comcast.net/~jofficer1/Blip_2.wav
Thanks guys! Yes, I am waiting on a custom full titan ARC single path exhaust (muffler and b pipe) and I have a tanabe y-pipe to complete the exhaust path. I should have it in little over a month. I'll be sure to post up more sound clips, when it is installed (and I'll get some from outside to capture the sound better)
--I'm very pleased with them as wellHave you experienced any thrown cel's after install of the PE cat's? The car pulls great, but I guess the tech says the 02 sensors after the cat need to be tricked to avoid throwing a cel. He's machining something for me that he did for his evo--so hopefully that'll take care of the cel--mostly to pass emissions (IL doesn't do a sniff, but they won't pass you if your throwing this kind of cel).
Unfortunately, that is a common issue with high-flow CATs, higher temps and flow rate can cause the error codes. There are O2 simulators available at most auto stores, or fabricating a plug nonfouler patch, as in your case.
G
G
Originally Posted by jonnylaw
^^Thx, the endless BBK will be installed in about a week or two. I'll be sure to post of some pic's once they are installed.
