HELP!! Emange Ultimate Upgrade
on
Today my car was running just fine. I came home on a lunch break and decided to update my Emanage Ultimate from ver. 1.09 to ver 2.12. The update was successful on my PC. Then after I updated the main unit itself the car went to hell. The engine vibrates a lot at low speeds and at higher speeds until about 4k rpm. There is a strange exhaust noise that sounds like air escaping from a small source and making a pulsing noise. My ignition timing it the same as it was so is the injector duty cycle. My knock sensor reads 108% but it reads that even when the engine is off but the unit is still online. I have tried every different setting, advanced my ignition timing and retard it. Changed the injector maps, i mean everything. Can someone please tell me what is going on or at least help me?! I need my car for tomorrow so I don't have much time.
I can provide more information that is needed. Even a sound/video clip if thats what I have to do. PLEASE HELP!!
Forged Performance
Forged Performance
Big move upgrades can cause all kinds of issues. You will probably need someone to go in and change, update several settings. I can't even recall version 1.09, as its been such a long time.
If all else fails, can you simply go back to the original version? Mohds emange website should have all the firware versions for you.
on
I tried everything, I got a hold of the old version and firmware but that didn't work at all. I set everything back to the way it came when I first got it, and it didn't work.
A little update I have taken the Emanage out along with the wiring and am in the middle of resting my ECU. I tried that fast way to rest the ECU but it seemed all it did was clear my error codes. The error code reads Misfiring on Multiple cylinders PO300. So I have the battery off right now and i am resting the ECU by taking the 24 hour rest and seeing if that works. I will let you guys know how it goes later on tonight.
I was thinking about getting a UTEC since my emanage is not working right at all and I cannot rest it back to the factory settings in the main unit itself. Every time I try and do it, it keeps asking me if I wanna communicate with main unit, and I click yes but it just keeps asking me that and never connects. The difference I saw with the new update was that the connection message said Would you like to communicate withe Emanage and VMANAGE. I dont know why it thinks I have a Vmanage but o well.
on
Well the ECU rest did not work. I have emailed Greddy and am waiting for a response. Now the engine is giving me the error code P0302 = Cylinder 2 Misfire Detected. So I have no idea what to do right now. I really don't have the time to send out my ecu to be re flashed, I need this car for work and all. If anybody has any kind of help at all please give me anything you got.
Just a note when I upgraded to Ver. 2.12 I had the capability of the V-manage. I had control over the Valve Timing IN. However the data logger did not read anything nor when I plugged in minor values did it read anything either. Just thought I would add that.
PLEASE HELP!!!
Thanks
Chris
PLEASE HELP!!!
Thanks
Chris
The only thing I can think of is sending your ECU to technosquare for a flash. I don't know much about drivetrain and upper engine operations but I hope you didn't through some things out of synch thjat would cause inner-engine parts collisions.
So even with the EU taken out and the ECU by itself, you still get bad operations?
on
on
Update: I was working on the engine and I found that the coil itself on cylinder #2 is not working. There is voltage going into it but no spark, and the plug is good I check it. I will be going to the infiniti dealer after work today and picking up one. I will let you guys know what happens.
Dr. Wired
on
Damage
Here you can see the damage done to the coil. Seemed like it bubbled up and then cooled. I get the new coil Saturday morning around 10ish. So I will let you guys know if this solved my problem but I am pretty sure that is the problem.
Sorry for bad pic quality I had to take the pic with my phone.
(Bad coil on right)
(Bad coil on right)
on
Originally Posted by gqong
did you leave your car to the ON position(dash lights on) for awhile? I have heard this causes this but i thoguht the problem was resolved.
Call GT Motorsports to see how they avoid burning up couild because I have the EU while my turbo was on for MONTHS and the car was as reliable as form the factory.
I am not sure if it is because I used a patch harness as a bridge in between my EU and the stock ECU.
Apparently, avoiding burnt coils heavily depends on the quality of the install.
