Need help validating the diagnosis of dealership
Old Jun 13, 2007 | 09:32 PM
iceagetlc's Avatar
iceagetlc
Default Need help validating the diagnosis of dealership
From my throttle cutting topic, you'll see I had the following problems:
Thruttle cut to 1/4 when 1/2 to 3/4 throttle is applied. Heavy acceleration halted or sputtered. Cruise control is unusable.
Problem disentigrates after a mile of driving.
Here is the dealerships diagnosis:
YAW Control system is whacky. "System that controls the braking of engine under G's is off. When I turn left, the YAW says right. Readings are all messed up"
$800 for new unit.
Am I being thrown for a loop?
Old Jun 13, 2007 | 10:39 PM
justusS's Avatar
justusS
Done anything to your steering/shaft...or front suspension recently?
When did problem arise?
Old Jun 13, 2007 | 10:47 PM
iceagetlc's Avatar
iceagetlc
No suspension or steering work done at all. Only thing I can think of is that after I took it in there last, my tire pressure readings have been switched so that Rear reads the front tires, and F: reads the rear tires. But the tires themselves have not been switched...
Old Jun 13, 2007 | 11:18 PM
Fingers's Avatar
Fingers
I didn't read your other thread but I think there is a way to reset the throttle position. I'm not sure exactly what the procedure is called but there is some information I read about it on this site. I think the procedure is one of those where your ecu relearns the throttle positions. Hopefuly someone that knows what I'm talking about can link it.
Old Jun 14, 2007 | 12:03 AM
iceagetlc's Avatar
iceagetlc
If you're talking about the whole gas pedal thing, I did that. I got it to blink at me and ****, everything. Quite a few times actually.
Old Jun 14, 2007 | 12:30 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
$800 for new unit.
Sounds like BS to me. I don't see what the yaw sensor has to do with ECU going into limp mode...
I think one of the following may be the case, so I'd try these in order:
1st of all, if you have any check engine codes, which you don't mention, you should get those checked immediately
MAF dirty / damaged ... check it and clean with MAF Spray cleaner from autozone
Throttle body dirty ... check it and clean with Carburetor cleaner
After checking the above 2 items, FULLY RESET the ECU not by the pedal reset method, but by disconnecting the negative battery terminal overnight
Then, try the procedures here (not the ECU reset though, the ones relating to throttle):
http://www.technosquareinc.com/350reset.htm
Spark Plugs fouled ... check and replace if necessary
Old Jun 14, 2007 | 12:52 PM
gothchick's Avatar
gothchick
I think I'd also get a Consult II or Cipher on there and run a few logs to see what is going on with the ECU. I was able to diagnose excessive exhaust blockage that way... I agree with Wired that the Yaw sensor theory doesn't add up.
Old Jun 14, 2007 | 01:17 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Exhaust blockage? Can you PM me with some details?
Old Jun 14, 2007 | 04:29 PM
Moroccan_Mole's Avatar
Moroccan_Mole
i had this exact same problem, and just it resolved last weekend.
it was an ecu issue. it had to do with the brake switch.
basically the ecu thought that the brakes were applied when they were not, and was cutting power.
the dealer ordered a new ecu (under warranty) and it fixed the problem. they attributed the problem to a physical short in the ecu.
Old Jun 15, 2007 | 02:15 AM
iceagetlc's Avatar
iceagetlc
Wow, that's weird. It happened RIGHT after I installed my new LED tail lights... Possible explanation?
Old Jun 15, 2007 | 03:23 AM
Moroccan_Mole
i doubt it
Old Jun 15, 2007 | 05:19 AM
gothchick's Avatar
gothchick
PM sent...
Old Jun 15, 2007 | 01:15 PM
iceagetlc's Avatar
iceagetlc
Thank you, I have an appointment for next thursday to have that ECU replaced. Hopefully this is the solution, because if it really is the YAW thing, I'm gonna be pissed, haha.
Old Jun 15, 2007 | 01:19 PM
iceagetlc's Avatar
iceagetlc
Default Your ecu problem
i doubt it
Did your problem go away after a mile or so of driving, like mine? How similar was it to what I described?
Old Jun 15, 2007 | 01:33 PM
rcdash's Avatar
rcdash
you can disengage power to the yaw sensor (the vdc and slip lights will come on) to easily test the theory. look for a thread about putting in a switch to cut power to the yaw sensor (to allow burnouts, brake boosting etc).
i think if you look under the center arm rest, you can just disengage the harness to the sensor.
Old Jun 15, 2007 | 01:51 PM
Moroccan_Mole
pretty much exact. cruise control didn't work. the car would still rev up, but past maybe 3500 RPM it revved very slowly - like there was no power. If i put my foot to the floor it, would act like it would start to go, but there was no power.
it let up occasionally, very rarely .... and run fine, but it was random.
Old Jun 15, 2007 | 02:21 PM
iceagetlc's Avatar
iceagetlc
Bingo, down to the rpm and everything...
Old Jun 15, 2007 | 02:32 PM
Moroccan_Mole
make sure to bring all of your keys with you to the dealer, they will need to re-program all of them. also check your brake lights after thier done. mine stopped working, and i had to bring it back to the dealer.
Old Jun 15, 2007 | 03:34 PM
Fingers's Avatar
Fingers
Thatsb it do a search and you will see that there was a few guys having a problem just like you after led brake light install/ Dude go look at your old thread post #19 Send a PM to yoichi he responded to your old thread with same exact problem.
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Cashwin
Oct 1, 2015 06:36 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
