how many quarts in an 07's motor
Old Jun 14, 2007 | 09:47 PM
350Zimo's Avatar
350Zimo
Default how many quarts in an 07's motor
i have just changed my oil and it took almost 5 and a 1/2 quarts , read the manual and it says 5 so wtf did i do should i drain little bit or just leave it as it is now , seems smoother and kinda better , probably is mental feeling cuase i spent $70 on royal purple ,
Old Jun 14, 2007 | 09:48 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Do what the manual says. Overfilling is bad.
Old Jun 17, 2007 | 11:38 AM
blainer's Avatar
blainer
royal purple is really good. I used that on my mustang and made a big difference.
Old Jun 17, 2007 | 12:52 PM
UrbanTacticZ's Avatar
UrbanTacticZ
If you had a way of measuring, you generally want to put in as much as you take out.
Check your dipstick, if its high just drain some out.
On another note, buy one of these: http://www.fumotovalve.com/
Makes life easy
Old Jun 17, 2007 | 03:35 PM
350Zimo's Avatar
350Zimo
Default eeeeee
it is exactly 5 and 1/2 because i checked it and it was (is) to the max notch of the dipstick , i think it's the manual that is screwed up because it says 5 quarts , and i have 5and a half up to the max dot.
Old Jun 17, 2007 | 04:24 PM
UrbanTacticZ
I would drain a little to be safe. Overfilling is bad.
Old Jun 17, 2007 | 06:16 PM
TheGest's Avatar
TheGest
5 and 1/2 because, thats what my mechanic said too
Old Jun 17, 2007 | 08:40 PM
Bevo's Avatar
Bevo
I always put exact 5 quarts in and it's at H mark
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
