Weird check engine code (P1057)?
Old Jun 19, 2007 | 06:36 AM
002-M-P's Avatar
002-M-P
Default Weird check engine code (P1057)?
My check engine light has been permanently on for a long time...for what I assumed were test pipes. I put the cats back on this weekend so I can get it inspected soon...cleared the CEL and about an hour into driving it pops up again. I check it later using the gas pedal method and I thinl I am gettitn code P1057 (after the 10 slow flashes...10 flashes...5 flashes...7 flashes). However I can't find this code online so I have no idea what to look at. If anyone has an idea before I go to autozone today to get it read for real...let me know.
Old Jun 19, 2007 | 07:26 AM
VO...'s Avatar
VO...
Administrator
https://my350z.com/forum/maintenance-and-repair/280180-complete-list-of-engine-error-codes.html
Old Jun 19, 2007 | 07:34 AM
002-M-P's Avatar
002-M-P
There is no P1057 listed...hence the I can't find this code online comment.
Unless my 10 flashes was actually meaning a double 0, making it P0057, which is an o2 sensor, which might make sense.
Old Jun 19, 2007 | 07:35 AM
VO...'s Avatar
VO...
Administrator
perhaps
Old Jun 19, 2007 | 02:16 PM
002-M-P's Avatar
002-M-P
yep....it ends up it was 0057...02 sensor 2, bank 2
does anyone know if I can clear my cel just before getting it inspected and pass ...or is it like fords and other companies where you have to drive x-number of miles before you can get it inspected?
Old Jun 19, 2007 | 02:18 PM
VO...'s Avatar
VO...
Administrator
My Eclispe use to pop a code. I would reset it a few blocks from the vehicle inspection place. It always worked for me. Not sure about the Z though.
Old Jun 19, 2007 | 08:28 PM
MIAPLAYA's Avatar
MIAPLAYA
It depends. Some have done that but some in Va have stated the OBD2 scanner at the inspection station would tell them the O2 was not ready for testing yet if the ECU had just been reset.
Old Jun 20, 2007 | 05:16 AM
002-M-P's Avatar
002-M-P
Well I need to get it inspected this week before I pull the motor out for good...so lets hope it works for me.
Old Jun 20, 2007 | 05:19 AM
blasian's Avatar
blasian
I had P0058 which is the same just the other bank IIRC. It usually take a few minutes to come back on.
Old Jun 20, 2007 | 05:47 AM
Q45tech's Avatar
Q45tech
All vehicles with OBD2 require a significant number of cranks and cruise miles to SET the READY for emissions test flag to protect against FRAUD by resetting system in parking lot before the test!
Not ready, usually promotes a visual test by tech because they know you did a reset.
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
