RB26 Swap...final decision
Old Jul 12, 2007 | 12:22 PM
002-M-P's Avatar
002-M-P
Default RB26 Swap...final decision
Sorry guys...
http://mp-racing.blogspot.com/
Old Jul 12, 2007 | 12:30 PM
saberphx's Avatar
saberphx
Nooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooooooooooooooooooooooooooo
350Z84's Avatar
350Z84
So your selling it because it couldnt get inspected? Why would it not pass inspection?
Old Jul 12, 2007 | 01:27 PM
rocks's Avatar
rocks
LOL good thing i live where there are no emissions. If i were you I would find an old datsun 510 to put it in.
Old Jul 12, 2007 | 02:37 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Finish the swap and i'll trade you straight up. Im in Ohio, so no emissions to deal with here. I also got a nice mod list, but NA, so no worries about emissions
Old Jul 12, 2007 | 02:57 PM
002-M-P's Avatar
002-M-P
The issue is not emissions. I do not have emissions either. The check engine light will be on permanently and will never pass the OBD-II part of the inspection..
and that motor is worth almost as much as my car is, so I don't think I will be doing any trades
Old Jul 12, 2007 | 03:05 PM
350Z84's Avatar
350Z84
Do you know why the CEL is staying on?
Old Jul 12, 2007 | 03:07 PM
002-M-P's Avatar
002-M-P
The motor has never run in the car (only test fit)...and yes I know why the CEL will stay on all the time....none of the OE engine parts will be in there to be referenced to. No stock O2 sensors, crank angle sensor, etc etc etc.
Old Jul 12, 2007 | 03:09 PM
MIAPLAYA's Avatar
MIAPLAYA
Aside from no signal feed back which I think you could get away with why would the CEL be on? It should be no different then with an Fcon or any other standalone. Oh well either way best of luck on what you decide.
Old Jul 12, 2007 | 03:10 PM
MIAPLAYA's Avatar
MIAPLAYA
True but that could be remedied I think. We know what all the voltage and signals should be. An output only board feeding the stock ECM to make it think the motor signals are there should remedy that no? I am quite certain KPeirson could come up with something pretty quickly.
Edit:
Honestly a muti output signal generator would fix the stock ECM problem. Here's what I mean, Forget the factory gauges, etc. Rig up a multiple signal generator feeding the expected frequencies to the factory ECM motor monitoring input channels. All it needs to know when the car is on is that its on. It can assume idle, or whatever you want it to. All you need is the ECM powered up to control the BCM. As long as the ECM is on all the acessories will work regardless of engine state. So with the ECM being fed engine at idle signals it will never trip a code. Side affect is that the stock gauges won't read whats actually happening but so what? You can replace them with Autometer Nexus units anyways. That includes speedo, tach, fuel level, oil pressure, coolant temp, voltage, etc. Either way I think there's a way around this provided you have someone to program and build a board to simulate all stock engine parameters at idle. KPeirson could do this.
Old Jul 12, 2007 | 03:50 PM
UnderPressure's Avatar
UnderPressure
Check your PM's
Old Jul 12, 2007 | 04:07 PM
Gman2004's Avatar
Gman2004
if you get cel lights after the install just send your ECU to Sam at GTM with the codes it was throwing and he could flash the codes away. That's what he does for the FCONs he tunes. No cars come out of GTM with cel lights now.
Old Jul 12, 2007 | 04:19 PM
Greedy4nismo's Avatar
Greedy4nismo
that's disappointing to hear. that inline 6 is amazing
Old Jul 12, 2007 | 04:41 PM
redmike_02's Avatar
redmike_02
That sucks man. Looks like you were fairly far into it to give up.
Old Jul 12, 2007 | 06:51 PM
Quamen's Avatar
Quamen
That sucks. I mentioned in another thread that I could possibly help you make a new cross member if necessary out of tubes.
Oh well. Best of luck.
Old Jul 13, 2007 | 04:31 AM
NA&CH's Avatar
NA&CH
Damn MP so close. Goodluck with what you choose to do Hope to see you hang around...
Chris
Old Jul 13, 2007 | 05:52 AM
THE TECH's Avatar
THE TECH
Yeah I was looking forward to see this project finish. Sorry that it is ending like this.
Old Jul 13, 2007 | 06:11 AM
002-M-P's Avatar
002-M-P
Thanks guys. I know you all want to see it finished...hell I want to see it finished probably more than anyone. I have loved the 350Z world and will def stick around...probably be at ZdayZ next year too...considering it is so close to me
MIA: I understand that I could fool the ecu to not show a cel...but before you can inspect the car the ecu has to show a ready state which requires driving around with varying speed/engine rpms until the ecu shows that the evap. system, 02 sensors, 02 sensor heaters, and catalytic converter are working correctly. This is the part that I cannot figure out.
Old Jul 13, 2007 | 06:16 AM
fast kiwi's Avatar
fast kiwi
Booooo. that would have been amazing..
Old Jul 13, 2007 | 06:27 AM
MIAPLAYA's Avatar
MIAPLAYA
Wouldn't the ECU do that if you fed it bogus idle engine speed signals all the time. I believe the ECMs steady state signal is triggered off of time with engine input not mileage.
