4500 Miles to soon for Synth. oil?
Old Jul 16, 2007 | 09:01 PM
LandonZ's Avatar
LandonZ
Default 4500 Miles to soon for Synth. oil?
I just got my oil changed the other day in my 05, I just bought it and wanted to make sure it had good oil in there, so at 4000 miles I put in mobile 1 synth. in there..Will that be ok? or did I jump the gun and put it in there to early?
Landon
Old Jul 16, 2007 | 09:03 PM
Blacryan's Avatar
Blacryan
Perfectly normal,
Perfectly healthy,
Old Jul 16, 2007 | 09:04 PM
Teufel's Avatar
Teufel
I don't think it will cause damage or anything, but I know a moderator suggested at around 20K. An oil analysis he/she had done showed his/her car was still being broken in at 10K miles.
Also, from what I have read on here, M1 is not longer a level 4 syn. I would go for Royal Purple 10W30 or Amsoil.
Old Jul 16, 2007 | 09:43 PM
terrasmak's Avatar
Its fine at 1000 miles.
Old Jul 17, 2007 | 12:03 AM
Agree. Switch anytime that you want. Its just motor oil.
Old Jul 17, 2007 | 05:47 AM
Ruthless18x's Avatar
Ruthless18x
+1 I'm using Lucas Racing 10W30 and it has been great.
Old Jul 17, 2007 | 07:22 AM
LandonZ's Avatar
LandonZ
ok thanks for responses. I was reading on here where it had said that our motors were not broken in until like 20k, and i said well crap. But anyway, thanks again
Old Jul 18, 2007 | 02:29 PM
Kolia's Avatar
Kolia
Your '05 has 1/10th the mileage of my '05 ?!?!
I switched to synth on my first oil change. No reason not to really...
Old Jul 18, 2007 | 04:34 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
as you can see, many different opinions, we have had the best luck running non-synthetic for at least the first 1000 miles on a brand new engine, even to be a bit safer, 2000 miles, before switching to synthetic....
20,000 miles, woah! you would have passed the mark there as far as experiencing the benefits of synthetic oil if you waited that long!
Old Jul 18, 2007 | 06:19 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Waiting 4000 miles on an OEM engine is more than adequate...waiting to 20K miles is insane! With the super tight tolerances in an OEM engine, your engine is pretty much broken in when you drive it off the showroom floor. As a precaution, most people wait until 1500 miles or so before switching to synthetic.
Old Jul 18, 2007 | 09:01 PM
andrew538's Avatar
andrew538
Dude, hurry up n get that mobile 1 synthetic oil change!! I got it around 3k and I wish I did it sooner. When u change ur oil the first time, u also get rid of lots of little metal shiznit from ur new engine, in other word, u protect ur engine by cleaning it from inside out... I broke in a little over 3k, and it still runs aweson...80k
remember 2 warm up ur ride all the time if u want to maintain that power after years of driving and racing...
Old Jul 19, 2007 | 03:04 PM
michaeljr6's Avatar
michaeljr6
i do it every 5K miles
Old Jul 21, 2007 | 03:42 PM
Bevo's Avatar
Bevo
Had my first oil change with Mobil 1 at 3,750 miles and did feel a little smoother.
Old Jul 22, 2007 | 05:44 AM
SpeedRcr's Avatar
SpeedRcr
Landon
I swapped over at 1k miles...79k miles later no issues with engine oil consumption
Old Jul 22, 2007 | 06:00 AM
izmir41500's Avatar
izmir41500
i switched at 15k. change about 5k.
Old Jul 22, 2007 | 06:20 AM
zprincess's Avatar
zprincess
I switched to Mobil 1 at 1,000 miles. Many new cars come with synthetic oil to begin with. I don't see why you need to wait to switch. The object is to keep the parts from wearing.
My oil is tested every oil change to be sure there is no abnormal wear. Do any of you test yours?
Old Jul 22, 2007 | 07:07 AM
Cube's Avatar
Cube
Actually I'm pretty sure the latest news on this is that warming up the car by just idling it (ie use a car starter and let it warm up outside while you're still gettin ready for work in the morning) is worse on the motor than if you were to hop in, start it up, and then drive lightly on it till it's up and running. Something to do with carbon buildup I believe...
But back on topic, I'm at ~300 miles on the motor... is it recommended to stay with dino-oil for a bit longer with the Arias ED pistons? I thought I read about that... if so, when should I switch to synthetic?
Old Jul 22, 2007 | 07:30 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
the chrome top ring in the arias ED pistons will take longer to seal compared to a softer ring. Typically, running standard oil for the first 1500-2000 miles should be sufficient. I have always switched to synthetic at 2000miles on my personal engine (running arias ED).
Old Jul 22, 2007 | 08:01 AM
Cube's Avatar
Cube
Thanks
Btw, you get my e-mail?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
Stevo Z
Oct 3, 2015 09:14 PM
