My First dyno on my Uk Gt!!!
Old Aug 4, 2007 | 01:25 AM
djtimodj's Avatar
djtimodj
Default My First dyno on my Uk Gt!!!
Just thought id post because you guys know what you talking about with the Zed in the USA!!!
Any comments??
Old Aug 4, 2007 | 02:12 AM
gsazabi's Avatar
gsazabi
AT or MT? non rev-up I'm guessing? Looks about right.
Old Aug 4, 2007 | 03:45 AM
djtimodj's Avatar
djtimodj
Manual, non- rev up.
I few guys from the uk have dyno'ed there 280ps cars all mauals and not got anywhere near these numbers !!
apart from the plenum spacer what other mods will increase bhp With out losing out on low down torque ??
Old Aug 4, 2007 | 04:48 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Exhaust to included test pipes.
Old Aug 4, 2007 | 04:52 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Nice..........I guess
Old Aug 4, 2007 | 05:14 AM
Tac-M's Avatar
Tac-M
i don't get it ! is it 230? or 280? and why 4th gear? it should be 5th.
Old Aug 4, 2007 | 07:59 AM
djtimodj's Avatar
djtimodj
230 rwhp 286flywheel bhp.
It was the dyno operator that said to run in 4th even tho i said to run in 5th!!
He said 5th gives to high wheel speeds near the red line ? (140+mph)
Exhaust and test pipes increase flow but you lose backpressure so i thought you will lose torque low down with that set up ??
Old Aug 4, 2007 | 08:17 AM
Tac-M's Avatar
Tac-M
Yep, the speed is high... I could not rev all the way in my 07... It hit the speed limiter before it hit the rev limit
Yet the 5th is what you should use for a dyno. This is also why your dyno is a little on the low side.
Old Aug 4, 2007 | 10:10 AM
djtimodj's Avatar
djtimodj
my dyno is a little on the low ?
Im really please that it was that good ??
do you think it would make much differance in 5th ??
Old Aug 4, 2007 | 10:41 AM
gsazabi's Avatar
gsazabi
No your numbers are not low at all. In fact they're really good!
Stock 287 motors dyno around 235-240whp on Dynojet, and even lower on Dyno Dynamics.
Old Aug 4, 2007 | 11:07 AM
Tac-M's Avatar
Tac-M
Oops! Sorry for Dyno Dynamics it is good .
Old Aug 4, 2007 | 12:24 PM
rcdash's Avatar
rcdash
As long as the gear ratio corrections are in place, it shouldn't matter *that much* what gear is used for dyno... That looks like a very strong car to me - nice!
EDIT: it is interesting how the AFR jumps up lean at 3400 rpm...
Old Aug 5, 2007 | 12:56 AM
djtimodj's Avatar
djtimodj
Guys you talk about 287hp, the Uk version book numbers say 276BHP!
The AFR seams to be the same as mine on a lot of the 350z in the uk ??
Dyno operator said jap cars are some times mapped to run rich lower in the rev range to give low down torque ??
I was please with these numbers but now dont want to lose HP or TQ from bolt ons ??
What do you think ??
Old Aug 5, 2007 | 12:59 AM
michaeljr6's Avatar
michaeljr6
don't waste money on bolt ons...just go straight to the twin turbo
Old Aug 5, 2007 | 01:50 AM
djtimodj's Avatar
djtimodj
Twin turbo in the Uk ! im not made of money! haha. to do it over here with a built block like you should your looking at £20,000 plus!! Also the complete lack of tuners over here its crap!
Old Aug 5, 2007 | 06:58 AM
dovla's Avatar
dovla
For hp, BHP, see if http://en.wikipedia.org/wiki/Horsepower helps.
For Dyno Dynamics, unless some correction/conversion factor was used, your numbers are good, and very good if your car has no mods!
Your AFR curve is typical for V35DE, but rich (and atypical for non-revup) in your case. Adding breathing mods will make your AFR leaner and produce more ponies, aim for 13 – 13.5.
Old Aug 5, 2007 | 12:32 PM
djtimodj's Avatar
djtimodj
The mods i intend to do are the basics:
plenum spacer
HFC
true dual exhaust
3.9 FD swap
With the breathing mods as above should lean out the AFR a bit ?? It dose look like im running very rich .
Old Aug 5, 2007 | 05:00 PM
gsazabi's Avatar
gsazabi
You'll go lean with the breathing mods.
You might lose low-end torque by going true dual..well depending on the pipings.
Old Aug 5, 2007 | 07:00 PM
djtimodj's Avatar
djtimodj
When you say you'll go lean, is that the 13-13.5 good lean or the 15-17.5 bad lean ??
the true dual is the DC sports.
Old Aug 5, 2007 | 09:22 PM
gsazabi's Avatar
gsazabi
I'm talkin about 14+ bad lean. 13-13.5 is perfect actually.
Never heard of DC Sports True Dual..wasn't even aware that they make exhaust for the Z lol..
