Adjustable Cam Gears
Old Aug 5, 2007 | 04:10 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by meatbag
Oh you cant get the controller on its own?
no
Old Aug 5, 2007 | 04:50 PM
meatbag's Avatar
meatbag
Performance Motorsport made a set of billet sprokets at one point that were adjustable but you had to give up the variable cam timing system. Last time I talked to them they were like $1200. Im not sure if they even make them anymore since the restructure.
Old Aug 5, 2007 | 04:55 PM
Quamen's Avatar
Quamen
That almost seems to defeat the purpose. No?
Old Aug 5, 2007 | 06:28 PM
meatbag's Avatar
meatbag
I think the issue at the time was the ability of nissans vtc system to cope with huge cam profiles and high revs. Some shops were having the clutch device that is used on the revup motors "slipping" to a certain degree and than catching up to where it should be.
Also the billet gears were intended for drag setups mostly. Topsecret disables the vtc system on most of the big VQ installations that you see from them.
I may be wrong though.
Old Aug 5, 2007 | 08:52 PM
Quamen's Avatar
Quamen
I think that the reason they disable the VTC like you mention is because they don't want to use expensive EMS's like the Marielle (spelt wrong) to tune the cam phasing. Either that or they are not familiar or do not have it avaliable to them.
Other then that I truely can not see a reason to get rid of such a good device unless you are tunning your car for just a specific RPM range in which you will race the car.
Old Aug 9, 2007 | 05:33 PM
radiologue's Avatar
radiologue
Hey, Is anybody out there using the NISMO adjustable cam gears?
Why has NISMO stopped their manufacturing?
Is there a problem with them?
Prefer not to drop nearly $800 buck and delay the project again for something that has a problem or is just not worth it!!! Any input would be appreciated!!!
Old Aug 9, 2007 | 05:37 PM
Z1 Performance
Former Sponsor
The car is getting old at this point and everything they (NISMO) are doing is around the new VQ motor, and the upcoming GTR. So as the car ages, the old parts are no longer offered. Happens with the tuning arm of every Japanese manufacturer. The parts are offered for as long as they feel like offering them basically.
It's not a part you'll find in wide use here for a simple reason - I can think of maybe 4-6 people who have motor setups and cams that would warrant them. As such, its not a part everyone needs, and not a part alot of people buy. Factor that into the fact that very few ecu's on the market can even take advantage of them, and you've got a very very very narrow segment of people who even could use them if they wanted to. We've sold to date, about a dozen sets total, and the majority went to people who you'll never read about on the boards.
Old Aug 24, 2007 | 10:06 AM
nismology1's Avatar
nismology1
Originally Posted by kwame@z1
Please enlighten me on how these are two completely different products?
Here is another page for reference:
http://www.hks-power.co.jp/products/...on/valcon.html
One's a sprocket, and one's a controller. Indeed different.
Old Aug 24, 2007 | 10:07 AM
nismology1's Avatar
nismology1
Originally Posted by Z1 Performance
The Valcon is a plug and play controller for use with stock cam sprockets - lets you manually dial in cam timing. Problem is its not officially offered in the US, and not the easiest thing in the world to get interpreted instructions for.
Greddy V-manage. Who cares if it's not plug and play?
Old Aug 24, 2007 | 10:10 AM
nismology1's Avatar
nismology1
And why do people call the Nismo CVTC sprockets "adjustable cam gears"?
They're indentical to stock except they have a 55° sweep instead of the stock sprockets' 40°. If they're adjustable cam gears, so are the stockers. :laff:
Old Aug 24, 2007 | 11:45 AM
radiologue's Avatar
radiologue
true, which is why I decided not to bother.
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
RyansZ33
Sep 15, 2015 05:54 AM
