jwt flywheel swap
Old Aug 5, 2007 | 11:47 PM
kaminariZ's Avatar
kaminariZ
Default jwt flywheel swap
Hey guys, i was just wondering how hard it is to swap out a clutch and flywheel on the Z. What tools are needed, and what kind of problems would you expect to run in to. i'm going to use a lift just fyi. thanks.
Old Aug 6, 2007 | 06:15 AM
westpak's Avatar
westpak
SFZCC
It is not hard but, main thing is being able to handle the heavy tranny when removing it, only tool not everyone has is a torx bit for the flywheel bolts, the rest are all regular hex heads.
Old Aug 6, 2007 | 08:08 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
this job will be a bear on jack stands, due to the 150lb trans that you will need to muscle around and properly align. I would try to find use of a lift, and a trans jack.
Old Aug 6, 2007 | 08:25 AM
HondaKiller's Avatar
HondaKiller
pulling the tranny out of the Z is rather easy. Just make sure you have the JWT clutch alignment tools and you should be good. Also, if you haven't pulled a tranny out of a car before, then i wouldn't attempt this one. Nothing out of the normal, but every clutch swap has unexpected problems.
Old Aug 6, 2007 | 09:57 AM
kaminariZ's Avatar
kaminariZ
does anyone know of any good shops in the chicagoland area who can do the flywheel and clutch install for a good price, and do good work? thanks.
Old Aug 6, 2007 | 10:39 AM
Sharif@Forged
Forged Performance
GRD.
Old Aug 6, 2007 | 12:30 PM
JAM3Z's Avatar
JAM3Z
Phenom
pulling a transmission on jack stands has bad news written all over it, maybe even impossible, especially single handedly. pony up the dough and get it done right.
Old Aug 6, 2007 | 01:09 PM
kaminariZ's Avatar
kaminariZ
hey guys, i'm using a lift. i don't know where you got jack stands from. but read my original post. thanks sharif for the recommendation.
Old Aug 6, 2007 | 02:50 PM
Sharif@Forged
Forged Performance
ops...sorry I missed that in the original post. With a lift, and a trans jack, its not bad at all.
Old Aug 6, 2007 | 03:04 PM
yoichi's Avatar
yoichi
I just bought the only JWT flywheel and nothing came with it. Does the alignment tool come w/ the clutch then?
Old Aug 7, 2007 | 02:45 PM
JasonZ-YA's Avatar
JasonZ-YA
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/292139-diy-clutch-install-part-ii-jwt-clutch.html
i just did mine this past weekend.....fly wheel placement is crucial!
i revised a "how to"
-jason
SharX59
Sep 27, 2015 09:23 AM
