What's the "coolant bypass mod"?
Old Aug 14, 2007 | 08:53 AM
RedLeader's Avatar
RedLeader
Default What's the "coolant bypass mod"?
I used several different search terms and didn't come up with anything on a "coolant bypass" mod? I don't have any cooling issues, but I'm curious. Can anybody offer a quick explanation, or tell me how to better utilize the search function(grrrrrr!)
Old Aug 14, 2007 | 09:07 AM
XuperXero's Avatar
XuperXero
Basically a valve with a switch that blocks coolant from flowing into your throttle body to prevent it from heating the air. Nissan put it there to prevent the TB from freezing in winter...
Old Aug 14, 2007 | 10:14 AM
i8acobra's Avatar
i8acobra
I'm in Vegas, so I don't even have a valve. I just got a double male barb, took the two hoses off the TB and connected them together.
Old Aug 14, 2007 | 03:51 PM
VIZAGE's Avatar
VIZAGE
Here you go, check this link out. I hope this is what your referring to?
http://www.forgedperformance.com/sto...cat=316&page=1
Old Aug 14, 2007 | 04:06 PM
RedLeader's Avatar
RedLeader
Default coolant mod
So, on the one hand we're talking about routing coolant around the throttle-body, and Sharifs' solution sounds more like an internal modification. For $275.00 it must be more than a simple bypass...
Have a lot of boosted-Z owners done this? Back when my motor was built, the cooling solution was supposed to be a Koyo radiator and a Nismo thermostat. If it's not getting hot under high boost, is anything else warranted?
Bruce
Old Aug 14, 2007 | 04:08 PM
doug's Avatar
doug
https://my350z.com/forum/engine-and-drivetrain/195998-rear-cylinder-coolant-bypass-modification.html
Old Aug 14, 2007 | 04:26 PM
RedLeader's Avatar
RedLeader
Default many thanks
Doug-
That completely explains it and I can say I learned something today. I love the new discoveries that have developed as people gain more experience with these motors. Hats off to Doug for discovering it and Sharif for posting it
Old Aug 14, 2007 | 04:30 PM
doug's Avatar
doug
not me Doug though.. the other Doug from Crawford.. i am just the messenger
Old Aug 14, 2007 | 04:37 PM
i8acobra's Avatar
i8acobra
There are two different mods... The block mod is what I assume links were posted for. This is supposed to aid in cooling the motor. The other mod is the "coolant bypass" that bypasses the coolant around the plenum. This keeps the plenum cooler. The plenum bypass is the mod I was referring to in my previous post.
Chris350z03
Oct 8, 2023 07:19 PM
SharX59
Sep 27, 2015 09:23 AM
smithmt3
Sep 11, 2015 08:25 PM
Beater350z
Sep 9, 2015 03:36 PM
