clicking noise from rear when starting.
Old Aug 18, 2007 | 09:30 AM
texasZ350's Avatar
texasZ350
Default clicking noise from rear when starting.
i have this click click noise from the rear right side of my car when i start moving, in reverse or first, and only sometimes. pretty rare actually but its there sometimes. i know there is a TSB about it, something about the axle or driveshaft bolts needing to be re-torqued/re-greased and it sounds like that is exactly the problem, BUT, i got this noise after i slid into a sidewalk long story short the rain at just begun, i used to drive with VDC off, lost it hit the side walk from the front left side, now hearing this click noise from rear right. maybe the impact cause the bolts to loosen? i don't know, any help with this is appreciated.
Old Aug 18, 2007 | 09:33 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Are your wheels at all damaged? If the car is still clean, and no evidence of the impact - take it the dealer...you likely need the TSB - but at the same time, you could have a bad bearing, from the accident.
Rick
Old Aug 18, 2007 | 10:12 AM
texasZ350's Avatar
texasZ350
hmmm, if it was the bearing, would i only hear it sometimes? i figured i'd hear it alot. but this is just like random...
oh and could the impact have caused the weak bolts to loosen, cause like there is the TSB so maybe the accident just made it more....?
thanks
Old Aug 18, 2007 | 11:02 AM
ISMSOLUTIONS
thanks
It's not a bolt loosening thing..the TSB that is. From thr factory, the mating surface is not lubed - and it shoudl have been. it's actually a fix for an improper build technique. so the unit is removed, then lubed, then put back together.
As far as the bearings - yea, could be. It depends on the level of TQ/force being put on the bearings, if it is in fact an issue.
rick
Old Aug 19, 2007 | 02:21 PM
JSia's Avatar
JSia
i was hearing the same thing and i was so sad because i thought i was gunna have to take it to the dealer because i heard the clickin noise... turns out it was my lug nuts that were loose making the noise!! hahaha i felt so stupid =/
Old Aug 21, 2007 | 07:57 PM
friendlydacat's Avatar
friendlydacat
rick
I got mine lubed at the dealer and the click still occurs.
Old Aug 21, 2007 | 08:00 PM
ISMSOLUTIONS
OK - so they either didn't replace the bots and nuts and washers and re-torque - or there is something else wrong.
Have you gone back? What did they say?
Old Aug 21, 2007 | 08:03 PM
genegoesfast's Avatar
genegoesfast
It's definately the TSB. That's exactly what my car did and thats what the problem was.
Old Aug 21, 2007 | 08:21 PM
johnb350z's Avatar
johnb350z
i think thats what im hearing on my car, sounds like i have a piece of gum stuck on my tire or something, i have a 07 Z btw
Old Aug 22, 2007 | 01:38 AM
friendlydacat
They said it's normal and I should read about it in this website.
The problem is exactly as described on the initial thread.
Is there a link to this TSB so I can read about it?
Old Aug 22, 2007 | 01:55 AM
chihfeng28's Avatar
chihfeng28
I used to have the click sound on my rear axle, just bring back to NISSAN dealer , i had mine in WEST COVINA nissan, they did lubricated rear axle , for now I am fine~
Old Oct 5, 2008 | 09:40 AM
Dissenter's Avatar
Dissenter
I know this about a year from the last post, but recently my '04 Track has had a clicking noise in the rear on the driver's side.
According to the TSB NTB04-065b, the surface of the axle needs to be greased and new bolts, nuts, and cotter pin need to be installed. However......
I have also seen a TSB that stated the entire drive axle needs to be replaced. Does anyone have any inside information on the this?
Thanks!
Old Oct 5, 2008 | 09:10 PM
214_350z's Avatar
214_350z
i have the same sound on my back drivers side...some exact info would be great!
Old Oct 7, 2008 | 05:25 PM
Dissenter's Avatar
Dissenter
There is a TSB on this. I have attached the file. Nissan in Lancaster, PA just did both of my axles today (Oct.7) and the clicking is gone.
Old Oct 7, 2008 | 05:29 PM
Dissenter's Avatar
Dissenter
Sorry, the file is too big. Here is the TSB: NTB04-065b
Just "Google" it or go to Nissanhelp.com
Old Oct 7, 2008 | 05:45 PM
AVmagneticZ's Avatar
AVmagneticZ
i have that sound but its gone havent heard it in a bit. started after i was doing a little drifting. but only taking off in first slowley did i hear it. and it was rare to hear as well. but ive heard this is my old car to...so...i dont think its that big of deal. goes away anyways hasnt returned yet lol.
Old Oct 30, 2008 | 02:28 PM
03aeroZ's Avatar
03aeroZ
Is this free? Is it under the power train warranty?
Old Nov 10, 2008 | 07:33 PM
03aeroZ's Avatar
03aeroZ
^^anyone have any info? mine tends to do it more when it is cold out as well.
Old Nov 10, 2008 | 08:36 PM
singh's Avatar
singh
_______________
My cousin's G does this too. His makes a clicking immediately after pressing the gas pedal..
Old Nov 11, 2008 | 10:12 AM
bluezup's Avatar
bluezup
^^^yea would like to know if its covered by the drivetrain warrenty.. If it is im screwed.
