Question about spark plugs, wires, and other tune-up parts...
Old Aug 30, 2007 | 07:27 AM
gothchick's Avatar
gothchick
Originally Posted by davidv
I would go with the JDM distributor cap.
A JDM RSX Dist Cap??? Good for 50 whp at least~ Lol!
Old Aug 30, 2007 | 09:10 AM
NiZmO350's Avatar
NiZmO350
Well I must say, that this was very helpful, depite the jokes I still got, but hey, I walked into it. Anyway, in summary, i should simply change the plugs and clean the MAS and throttle body... I think that about sums it up?
Old Aug 30, 2007 | 09:16 AM
failsafe306's Avatar
failsafe306
Sounds about right. Wouldn't hurt to replace or clean (depending one which type you have now) your air filter too, since you'll have it off anyway.
Old Aug 30, 2007 | 09:21 AM
mpowers's Avatar
mpowers
All bs aside, don't worry about cleaning the MAS (mass air flow sensor) as you will run a risk of damage to it. Nissan's MAS is very sensitive to chemicals.
Also don't worry about cleaning the throttle body, but if you do remember you will need to do a throttle body relearn if you have manually moved the butterfly in the throttle body. If you do and don't do the relearn you may recieve a rough idle and maybe a check engine light.
Now your on the right track,
Mike
Old Aug 30, 2007 | 09:25 AM
NiZmO350's Avatar
NiZmO350
Thank you. I needed that after reading everyon's response.
BTW, failsafe306... love the pic of that bumper LOL...
Mike
Old Aug 30, 2007 | 09:42 AM
jtabraham's Avatar
jtabraham
If done properly, you won't risk damaging your MAS. I suggest using a spray made by CRC Industries specifically for these sensors. Just be careful not to make contact with the sensor's wires when spraying it down.
burglapfd
Dec 6, 2020 01:04 PM
nanotech
Oct 2, 2015 05:02 AM
