3.9 final drive on 07
Old Sep 8, 2007 | 09:27 AM
nareg's Avatar
nareg
Default 3.9 final drive on 07
Can the 3.9 final drive go onto the 07 z? just got one and the gears are too long.
Thanks
Old Sep 8, 2007 | 09:47 AM
Tac-M's Avatar
Tac-M
yes it is the same diff.
Old Sep 8, 2007 | 11:50 AM
shifty711's Avatar
shifty711
There is a member with the 4.08.
He likes it.
If I were you i would get the 4.08.
03-06 Z's ~ 3.9
07+ Z ~ 4.08
Just my opinion
Old Sep 8, 2007 | 01:21 PM
nareg's Avatar
nareg
where do i get the 4.08 from and do i need a limited slip for it
Old Sep 8, 2007 | 01:25 PM
jonnylaw's Avatar
jonnylaw
mynismo.com
Old Sep 8, 2007 | 01:32 PM
nareg's Avatar
nareg
thanks
Old Sep 8, 2007 | 01:34 PM
plumpzz's Avatar
plumpzz
Personally I'd get the 3.9 to retain some decent gas mileage. Either way you can't go wrong, and it'll be MUCH faster
Old Sep 8, 2007 | 05:46 PM
Delako's Avatar
Delako
I was going with exhaust as my next mod but the 3.9 seems like the obvious choice now.
Old Sep 8, 2007 | 05:53 PM
Bottled Water's Avatar
Bottled Water
how would a 4.08 be on a 04??? what kind of 0-60 and mph in gears 1-5?
Old Sep 9, 2007 | 05:45 AM
Q45tech's Avatar
Q45tech
Since MPG is ~~= to rpms a decent rule is to apply the gear ratio, if 20% higher ratio expect some like 15-20% lower MPG in steady cruise [highway] MPG.
The are some variable since volumetric efficiency changes with rpm and load.
Acceleration is ~~= to the cube root of ratio increase 20%= ~3.1% less any extra time spent shifting into an extra gear.
Old Sep 9, 2007 | 10:35 AM
nareg's Avatar
nareg
the final drive on a stock 07 is the same as the 03-06 right
Old Sep 9, 2007 | 05:03 PM
OCG35's Avatar
OCG35
the FD on the 07 G sedan is 3.7 (I'm pretty sure the 08 coupe is too)... the Z will probably have that as well?...
Old Sep 9, 2007 | 06:16 PM
ncdoc's Avatar
ncdoc
The 07Z has the same final drive as 03-06, they didn't change it as in the G coupe. I have the 3.9 in mine, and I would have took this as an option from the factory if it existed. I haven't had a chance to put too many miles on the new gears yet, but the car is much more lively. RPM's are up about 300 in each gear at steady speed compared with the 3.5. Haven't had enough time to see the hit on mpg.
ncdoc
Old Sep 9, 2007 | 08:02 PM
VitViper's Avatar
VitViper
I've got the 4.08 and if you're going N/A in an 07, it's the FD to use.
Old Sep 9, 2007 | 08:45 PM
nareg's Avatar
nareg
can you order the final drive already in the lsd because i have a base model and i am guessing that i need an lsd to use the 4.08 fd
Old Sep 9, 2007 | 08:48 PM
nareg's Avatar
nareg
and also how long does it take to get in usually? is it like a month wait or sooner
Old Sep 12, 2007 | 07:20 AM
Anomaly460's Avatar
Anomaly460
with the 4.08, at what speed 1st gear end (hit redline) ?
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
