Help ID this differential
Old Sep 12, 2007 | 02:02 PM
bimmerPower's Avatar
bimmerPower
Default Help ID this differential
I'm a bmw guy but I got this diff from a local auction in a lot. Looks new, is a lsd, I can tell it's from a nissan from ebay pics I believe . Any help would be great so I know what I have. Then figure out what to do with it.
Old Sep 12, 2007 | 02:13 PM
Kuruma-san's Avatar
Kuruma-san
check it for any part numbers
Old Sep 12, 2007 | 02:21 PM
bimmerPower
painted on is 829C, casted is 8250 and 2 OCO
Old Sep 12, 2007 | 04:16 PM
n1sm0r's Avatar
n1sm0r
Looks like a 350z differential. Definetly not a 240sx/j30/300zx/r32/r33 differential
Old Sep 13, 2007 | 10:04 AM
JoeyFyed's Avatar
JoeyFyed
Someone might buy it, post it up in the classifieds.
Old Sep 13, 2007 | 11:09 AM
DustinZ33's Avatar
DustinZ33
+1 on 350z, don't know if its open diff or vlsd.
Old Sep 13, 2007 | 11:14 AM
rookie's Avatar
rookie
If you knock out the side flanges/output shafts you should be able to tell if it's vlsd or not.
Old Sep 13, 2007 | 02:12 PM
bimmerPower
what about pulling the cover and checking it that way? I believe it's a 3.3 for an automatic. What would I look for if I pulled a side flange ? Also whats it worth ?
Old Sep 13, 2007 | 03:17 PM
n1sm0r's Avatar
n1sm0r
You can probably get upwards to $300-400 for it. I see VLSD cores go for $200 on craigslist every two months or so. Since you still have pumpkin that'll probably bump the price a little
Old Sep 21, 2007 | 03:50 AM
bimmerPower
I'll put it on Dallas Craigslist
Old Sep 21, 2007 | 03:52 AM
rcdash's Avatar
rcdash
You can pm helldorado about it - he's on here once in a awhile and has some experience with the different diffs. You can also post on nicoclub.com as all the nissan guys (from 240 on up) hang out there and they've done all types of diff swaps.
Old Sep 21, 2007 | 04:07 AM
WalkerT's Avatar
WalkerT
Professional
Does both of the stubs spin the same way when turning one of them?
if they spin the same way then it is a lsd
put a white mack on the input shaft. spin the stub shaft. count the revolutions. If it make 3 and a half then it is a 3.5 if it only make 3 and 1/4 then it is a 3.3.
You still will have no Idea how many miles that are on it or how it was used.
By the way you should have taken my offer.
-Travis
Old Sep 21, 2007 | 04:27 AM
WalkerT's Avatar
WalkerT
Professional
here are the part numbers they will be stamped in the case
base - 38301-0c422
lsd auto - 38301-2c322
lsd manual -38301-2c422
Old Sep 25, 2007 | 02:51 PM
bimmerPower
well it's definantly a lsd. Both hubs turn same direction. It's a 3.357 vsld for a 03-06 ( possibly 07) 350Z automatic. 3.357 ratio only came in those years per nissan. Opened it up and it's clean clean clean. I decided to Flea Bay it. It's on there now. I don't recall any offers from here also,
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
Nothing
Nov 3, 2003 01:39 PM
