Do engine dampers put more or less stress on exhaust components?
Sorry but I don't think that is a good idea to use a torque dampner on the intake manifold. While the higher up on the engine the better its mechanical advantage will be, where that engine dampner is mounted is also on the furthest out part of the intake manifold. This is the highest mechanical advantage over the bolts that mount the intake manifold to the lower runners to the heads will be which is not what you want.
The Weapon-R damper doesn't affect how the mainfold is attached. It uses one of the mounting points for the engine cover, and another under the cover where nothing else is attached, to begin with. So no internals are tampered with.
Originally Posted by Quamen
Referring to this picture:
Originally Posted by Wired 24/7
I've heard the Stillen engine damper is not really a damper piston, it just looks like like a piston / shock absorber.
Originally Posted by thinking
Has anyone substantiated this claim?
Originally Posted by undrgnd
Why would anyone want to put hundreds of pounds of force on the side of the manifold? That, and those fugly welds, I'm going to get the Stillen.
Justin100
Nov 29, 2015 03:58 PM
