Warranty Tranny SOS
Old Oct 4, 2007 | 08:45 AM
sixsigmalarry's Avatar
sixsigmalarry
Question Warranty Tranny SOS
Hello! I have been having slight issues with my tranny in my '03. The usual rough shifting into 2nd and 3rd. Of course, the dealership say's that it's normal with ALL Z's.
Anyone have any advise how I can make my tranny more obvious that it is in need of Warranty work?
By the way, my Warranty is up in 5 weeks.
Thanks!
LC
Old Oct 4, 2007 | 08:48 AM
cheshirecat79's Avatar
cheshirecat79
Is it grinding as if the synchros are going bad? If so, are there any other dealerships you can take it to in the area where you wouldn't have to deal with a hard-headed service department?
"Rough" shifting is a pretty broad term. If you've got grinding, it sounds like the '03 tranny issue. Could you be more specific?
Old Oct 4, 2007 | 08:57 AM
sixsigmalarry
It shifts "loud"-a mechanical noise, not so much grinding, but I can feel it in the shifter. And then when I take it out of that gear and place it back, it's fine. Worse cold and if I shift slower, it's not as bad.
Old Oct 4, 2007 | 08:58 AM
rcdash's Avatar
rcdash
You're gonna have to research the TSBs, and then go complaining and be persisitent if you want the latest version tranny swapped in within the next few weeks... good luck.
Old Oct 4, 2007 | 09:52 AM
cheshirecat79
I agree that the 350z's tranny is very loud and "mechanical" feeling along with the clutch. It's by far the loudest tranny I've driven. If it's not grinding, you may have problems getting the tranny replaced.
Out of curiosity, have you driven or rode along with another z driver to compare your transmissions? If you could, it should be the same year/tranny model if you can, so you can have an apples to apples comparison.
Even test drive the 07 and see if it has the same "Feel". Chances are it will not since it has the new model tranny, but either way you might be a little more informed and ready to make a case for yourself.
Old Oct 4, 2007 | 10:29 AM
krnzzang84's Avatar
krnzzang84
I just got mine replaced from dealer!!!
mine was grinding bad after 4.5k shift going second to third!!!
They replaced mine with new 009 transmission!!! New Trans, Clutch, flywheel!! so happy !
Guys after i got a new trans, clutch is sooooo light compare to one i had before!!! Is 009 Trans's clutch light like that or is it going to get harder later??
Old Oct 4, 2007 | 12:42 PM
Studah's Avatar
Studah
OP, I am having the same problems with my Z also, its a 03 touring, but only grinds if i shift too fast (2nd to 3rd) when the car is still cold but if i let the stick slide right then push it up slow it won't grind ( it might not even be grinding, more close to how you described it mechanical), I took mine in but they also told me it was normal gonna try again this weekend let me know how yours turn out, but it doesn't grind a lot either so I don't know whats going on
Old Oct 4, 2007 | 12:45 PM
krnzzang84's Avatar
krnzzang84
just insist!! and they will change it!! 009 trans is much better so much smooth but has really really light clutch!!
Old Oct 4, 2007 | 01:20 PM
SargentZ's Avatar
SargentZ
try another dealer, we have a least 5 Nissan dealers in my area. Some are better than others.
Old Oct 4, 2007 | 06:53 PM
sixsigmalarry
Unhappy
Here's the deal, I talked with a buddy of mine who works at the dealership, he ran the VIN and the tranny was replaced at 12K w/a 009 tranny.
I've heard they shift as smooth as 'butter', but mine is not this way. I'll try to test drive another Z VERY soon.
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
EnjukuRacing
Sep 9, 2015 06:42 AM
