Stillen 5AT Valve Body Upgrade
Old Oct 4, 2007 | 11:24 AM
Fairly Z's Avatar
Fairly Z
Default Stillen 5AT Valve Body Upgrade
So, I've got an '06 5AT Z, and I want to do the Stillen shift upgrade. You send out the transmission valve body to them, and they modify it, making it shift firmer and quicker. Has anyone done this upgrade, and is anyone experienced with its affects on the transmission warranty? The car's got 2 grand on the odo... Thanks!
Old Oct 4, 2007 | 11:58 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Dont waist the money on the stillen,i took a ride in a stillen equipped car and the shifts were a little faster but not by a lot.I went and bought a forged performance vb and boy does it shift fast.I did a full boost run and it chirps 2nd,3rd and i got a little chirp into 4th and it does not hit the rev limiter anymore. Since i dont think forged does them anymore go and get one from sgp.......more money but worth it.
Old Oct 4, 2007 | 12:07 PM
Fairly Z's Avatar
Fairly Z
SGP? Do they have a website? Also, did you void your tranny's warranty?
Old Oct 4, 2007 | 12:08 PM
iStan's Avatar
iStan
ZR
http://www.sgpracing.com/
Hell yes it will void it.
Old Oct 4, 2007 | 12:42 PM
Z_Driver's Avatar
Z_Driver
Master
You have fo pay to play is my motto. Just go for it !!! The worst thing that can happen is you'll have to rebuild your tranny for $3K. Well worth it in my opinion. Don't forget, a quicker shifting tranny in daily use has less slipage and thus makes your tranny last longer. However, if you plan to chirp every gear you can no cars tranny will last very long. ;-)
Old Oct 4, 2007 | 12:51 PM
superchargedg
Damn Noobs
Well since i put a supercharger on 5 months after i bought it..................well what do you think about the warranty.And now with the greddy twins........what warranty. Also if you do a vb def get a trans cooler to keep the temp,s in there optimal range.
Old Oct 4, 2007 | 01:02 PM
Z_Driver's Avatar
Z_Driver
Master
Whoa - Maybe you should have bought a Viper or Vette ???
Yes you are nuts !!! Lol !!! But, I can understand your love for the Z/G. It's tossable that is why I'm on my sixth Z. ;-) For the cheap power play I had to go LSx* route. However, for you it looks like money isn't an issue. That's a good thing !!!
* LSx = LS1, LS2, LS3, LS6, LS7 ..... for those that don't like or know GM.
Old Oct 4, 2007 | 01:52 PM
Fairly Z's Avatar
Fairly Z
Tossable? Maybe I would've gotten a GM if the level of engineering was anywhere close to half of the Z's! lol, but anyways, my car's got 2000 miles. Maybe it's best to wait?
Old Oct 4, 2007 | 01:57 PM
iStan's Avatar
iStan
ZR
2 months here... Nissan and I don't get along too well
Old Oct 4, 2007 | 03:03 PM
superchargedg
Damn Noobs
Yes i am a nut case for dumping the money into this car..............but all the labor is free cause i do it all myself and it,s fun.I may be a lot older then you guys but quess what i still like to rape people on the street and the track.
Old Oct 7, 2007 | 04:22 PM
BJZED's Avatar
BJZED
I had Stillen's autobox upgrade done on my 2006 Z, (I also have a Stillen s/c )
and I found it gave a useful improvement - for sane street use. VERY brisk changes from a standing start. Good value I think, but it depends on what you expect from the car and how much you abuse it...
Old Oct 7, 2007 | 05:51 PM
helldorado's Avatar
helldorado
Don't worry about warranty. Unless a valve body destroys your transmission, there's nothing they can do to use it against you for regular warranty work. Unless they notice the faster shifts on a test drive, its undetectable to a tech.
The only advantage to waiting for a car to get out of warranty is well... you have an old car without a warranty instead of enjoying it now.
I always knew you had that molester look to you.
Old Oct 8, 2007 | 05:42 AM
Fairly Z's Avatar
Fairly Z
65,000 is a LONG time to wait. So, the warranty's out the window. Essentially, you buy a Z without a warranty, I guess - they're not stupid, they know you'll modify it. I think I'll do the Stillen one, after all. It's for the street, not the track. Will a stock AT Transmission with the Stillen upgrade be able to handle the APS twin turbo setup?
Old Oct 8, 2007 | 02:45 PM
superchargedg
Damn Noobs
It can barely work with n/a and it will def not be able to shift fast enough with turbo,s on the car.
superchargedg
Damn Noobs
I always knew you had that molester look to you. [/QUOTE]
Rev_Night
Nov 7, 2020 06:00 PM
