does the VQ35 Z engine have a harmonic balancer?
Old May 25, 2003 | 01:19 PM
N74DV's Avatar
N74DV
Default does the VQ35 Z engine have a harmonic balancer?
does the Z engine have a harmonic balancer a.k.a. tuned mass damper?
I've taken a peek down the front of the motor and can't see a separate harmonic balancer and it would appear that the stock crank pulley is not a 2 piece design with rubber absorbing ring....
makes me think there is no balancer on the VQ
Old May 25, 2003 | 02:00 PM
MannishBoy's Avatar
MannishBoy
Much controversy on the subject. Supposedly, the engine is internally balanced, but there is a difference of opinion on whether it is dampened from longitudinal vibration. I'd not seen the crank pulley off.
Old May 25, 2003 | 02:04 PM
N74DV's Avatar
N74DV
yeah I hear all this about "internally balanced" as well...
a balanced crank doesn't mean jack against harmonic distortions. a mass tuned damper cancels out these harmonic distortions at specified resonate frequencies...
an internally balanced engine is great.. but the crank can still suffer from harmonic distortion...
I'm pulling my pulley off this week to install an UR crank pulley... I'll see if it's a 2 piece then I guess...
Old May 25, 2003 | 02:18 PM
MannishBoy's Avatar
MannishBoy
Definitely let us know, and post close up pics
Old May 25, 2003 | 03:09 PM
teh215's Avatar
teh215
From the thread by MaxHax (https://my350z.com/forum/showthread....0&pagenumber=3)
Photo: http://home.attbi.com/~wegetourmail/...ID-698983.html
Old May 25, 2003 | 04:25 PM
MannishBoy's Avatar
MannishBoy
You can't tell from that pic.
Old May 25, 2003 | 04:53 PM
N74DV's Avatar
N74DV
yeah... I've seen that pic and it's not really showing much. The damper ring is only about 4mm thick on most damper/pulleys. On our pulley it's likely that the damper ring could be recessed between the inner and out pulleys.
That shot shows the inner side of the pulley which could very likely be one piece with the outer pulley attached by a bonded damper ring which could only be seen up close from the other side.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Nov 9, 2015 11:10 AM
