2006 350Z - Oil Pressure Problem
Old Oct 12, 2007 | 12:55 PM
04DBZ's Avatar
04DBZ
Default 2006 350Z - Oil Pressure Problem
Uhh my oil pressure is reading at between 0-30 and just got a fresh oil change is anyone else having this problem with their 06......its been like this for the past 3 oil changes...and the dealership is no problem because it is below 14.....
Old Oct 12, 2007 | 12:59 PM
n1sm0r's Avatar
n1sm0r
Low oil pressure:
Could be...
1. Bad oil pressure sender
2. Bad oil pump
Old Oct 12, 2007 | 01:04 PM
calin's Avatar
calin
i have the same problem with my 06. but my pressure is only low about 2000 miles after an oil change. its happend after every oil change so far. i talked to a dealer about it and a guy told me its most likely the sending unit. gotta go in and get it fixed sometime
Old Oct 12, 2007 | 01:05 PM
VO...'s Avatar
VO...
Administrator
This is normal....
Old Oct 12, 2007 | 01:14 PM
J0n051's Avatar
J0n051
is that even in the cold?
Old Oct 12, 2007 | 01:28 PM
VO...'s Avatar
VO...
Administrator
Outside temp has no drastic effect on the engine oil pressure once the vehicle has reached operating temperature....
Old Oct 12, 2007 | 04:27 PM
fabulousfairldy's Avatar
fabulousfairldy
So on idle the psi should be around 50? mine drops close to about 10 or 20 psi??? closer to zero on idle but on the gas it will go to about 60 depending how hard im driving.
Old Oct 12, 2007 | 06:03 PM
n1sm0r's Avatar
n1sm0r
When the car is fully warmed up
1. Idle must be ~20psi
2. 3000rpm must be atleast ~60psi
Old Oct 12, 2007 | 08:17 PM
trains1937's Avatar
trains1937
Originally Posted by vo7848
This is normal....
Mine sits at or slightly below 30 at idle when its warmed up. Under power it can go up to 60 or slightly higher when accelerating.
Old Oct 13, 2007 | 01:22 PM
raihansdg's Avatar
raihansdg
15~20 psi normal at idle when the engine is warm, also check the manual
Old Oct 14, 2007 | 11:35 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The OEM gauge is notoriously inaccurate. I have seen them read zero, and seen them maxed out at 120psi. When we install aftermarket oil pressure gauges, the readings are usually very different from the OEM gauge.
Old Oct 14, 2007 | 11:49 AM
GolfinZ's Avatar
GolfinZ
Mine at idle, after driving it for 20 min or so, sets at ~15 psi. When cruising about 3000rpms, it sets at ~65. At WOT its ~75ish. And +1 on what Sharif said
Old Oct 28, 2007 | 04:54 PM
The_man_in_Black's Avatar
The_man_in_Black
I have an 06 6M/T and I have the same problem I Idle at about 15 or less psi after the engine has warmed, it also seems to idle kinda rough
Old Oct 29, 2007 | 10:06 AM
Q45tech's Avatar
Q45tech
Idle oil psi is always at its worst with fresh oil and filter, before the light fractions burn off.
15 psi [with an accurate gauge] is plenty at extremely hot idle rpm
reno56
Interior
17
Nov 20, 2015 05:21 PM
Vigman
Nov 17, 2015 04:34 AM
nissan1310
Oct 12, 2015 08:54 AM
RyansZ33
Sep 15, 2015 05:54 AM
Inspatatrac
Sep 8, 2015 02:12 PM
