Check out what I made for the VQ35
Old Nov 2, 2007 | 06:29 PM
  #41
Lawn Dart's Avatar
Lawn Dart
Great looking product! However, I'm a little concerned about putting steel and aluminium together where moisture can hit it, considering this is a formula for galvanic corrosion. Have you taken any measures to try and prevent this?
Old Nov 2, 2007 | 06:32 PM
  #42
jcpeyton's Avatar
jcpeyton
I'm ready to swap pulleys, and I don't mean to be dense, but I still don't understand the response. The response says "...by now installing the seal, you could prematurely wear away the seal because the clearance is now too tight on their component..."
Maybe someone can tell me exactly what that means. Thanks.
Old Nov 3, 2007 | 07:50 AM
  #43
Irongrave's Avatar
Irongrave
basicly he needs to do some work on the product before he'll have it out to the public ie he's testing it still.
Old Nov 3, 2007 | 08:19 AM
  #44
SpeedRcr's Avatar
SpeedRcr
wonder if he is going to put a steel sleeve on the inner mount
Old Nov 3, 2007 | 09:20 AM
  #45
jonnylaw's Avatar
jonnylaw
there is a steel sleeve and will said the underdriven pulleys will be ready to ship sometime next week. Did u guys check the thread in the marketplace (vendor group buys)?
Old Nov 12, 2007 | 07:38 AM
  #46
wperdigon's Avatar
wperdigon
The aluminum is made from 6061 marine grade aluminum and is designed for corrosive environments - the sleeve is also pressed in, so no moisture will be able to penetrate the seal
Old Nov 12, 2007 | 07:39 AM
  #47
wperdigon's Avatar
wperdigon
yes i did put a steel sleve on it
Old Nov 12, 2007 | 08:11 AM
  #48
SpeedRcr's Avatar
SpeedRcr
when are you going to start stamping them out?
Old Nov 16, 2007 | 10:59 AM
  #49
wperdigon's Avatar
wperdigon
I have finished making the underdriven ones - check out the group buy section for them
Old Dec 6, 2007 | 08:47 PM
  #50
psiclne's Avatar
psiclne
Any feedback from the guys that got this?
Old Feb 26, 2008 | 07:19 PM
  #51
Steve-O Z33's Avatar
Steve-O Z33
Any updates/feedback? What belt size does this require? I'd like to run a goodyear belt if you have the size and/or part #. I'm going to be buying an underdrive pulley very soon. I'm interested in this one.
Old Feb 28, 2008 | 01:29 PM
  #52
psiclne's Avatar
psiclne
I bought the stock sized one.....so I cant answer the size of belts to use. But as for performance, I noticed that the RPM's climb up a bit quicker.
Old Feb 28, 2008 | 09:29 PM
  #53
HR_Z-Ballz's Avatar
HR_Z-Ballz
Originally Posted by ZLadie2000
ANy confirmation on 07 crank pulley yet?
Also what about dyno results for this product??
Yes, they are indeed different as Forged motor sports has proved this with their 07' HR engine dissection thread.
It's so difficult to wait for the after market support to build up when you have such a bad @ss car!
Old Apr 22, 2008 | 09:10 PM
  #54
tranceformer95's Avatar
tranceformer95
Has this part even been tested????
sales@czp
Sep 23, 2019 03:30 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
