Anyone try these tricks for more power
Old Dec 3, 2007 | 09:33 PM
jdemos's Avatar
jdemos
Default Anyone try these tricks for more power
The link below is a great write up on tips for squeezing more power out of your car. Anyone try this stuff? Besides syn oil of course.
http://images.google.com/imgres?imgu...eIj4mc4O&prev=
Old Dec 3, 2007 | 09:38 PM
Nexx's Avatar
Nexx
you try them, let us know how it goes.
Old Dec 3, 2007 | 09:39 PM
roxtarinc's Avatar
roxtarinc
be careful people have blown built engines after doing those mods.
Old Dec 3, 2007 | 09:40 PM
jdemos's Avatar
jdemos
hahahahah
fairladyinit's Avatar
fairladyinit
lol don't waste your time
Old Dec 3, 2007 | 10:40 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
the motordyne isothermal spacer kits come with a throttle body coolant shutoff valve...
our IAT sensors are together with the MAF, no need to relocate
indexing the plugs for 1whp, not worth the effort if it even works
synthetic oil, sure.... but on these cars it's doubtful you'll see whp increase
Old Dec 4, 2007 | 04:57 AM
QuadCam's Avatar
QuadCam
you don't need the motordyne kit to bypass the throttle body. go to napa (or simialr) and get the correct size hose for the coolant lines that goes to the throttle body. you'll need a length of hose less than 3 feet long (IIRC.)
remove the coolant lines that run in/out of the throttle body. BTW, do this mod when the engine/coolant are cold! Also, remove the lines where they attach to the coolant pipes.
take you new hose and cut it to length so that you can run the hose directly from the driver's side coolant pipe arounf to the back of the engine where it hooks back into the coolant pipe coming off of the back of the heads. secure the hose with the stock clamps or get get some small worm-gear hose clamps.
Voila! throttle body coolant bypass mod! should cost you about $2-$5!
someof you might be wondering "why don't you just put a cap on each nipple on the coolant pipes?" the reason is that there aren't any good caps that will take the heat and pressure of the coolant system over time. I tried it, and within a few months, one of the rubber caps had started to crack and I had a small coolant leak.....if left alone, it would have become a geyser!!!!
Old Dec 4, 2007 | 09:50 AM
SpeedRcr's Avatar
SpeedRcr
you forgot about adding stickers for manufacturers all over your car, adding neon, sticking on a wing big enough for a 777, and of course the flaming exhaust
Old Dec 4, 2007 | 05:45 PM
undrgnd's Avatar
undrgnd
I tried them all at one time or another. If the claims are up to 5 hp on a dyno, no wonder I never felt anything. I seriously doubt most of these make ANY difference, unless icing of your TB counts. It happened to me before, and I won't be bypassing any TBs in the future.
Old Dec 4, 2007 | 05:48 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Our VQ's run better off of Diesel, yes Diesel fuel. Put 10 gallons of Diesel in with 1/4 tank of 91+oct and = GOOD times
shhhh-dont tell anybody my secret
Old Dec 4, 2007 | 11:07 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
^^ heh.... yeah and you don't even need spark plugs
Old Dec 7, 2007 | 11:59 AM
mavtais's Avatar
mavtais
Just about every Honda motorswap guy I know has a blown motor. I wonder how many motors this guy has killed?
loudtoyz
Apr 6, 2023 04:52 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
