Rattling noise when turning off engine
Old Dec 17, 2007 | 10:41 PM
folddem's Avatar
folddem
Default Rattling noise when turning off engine
When turning off the engine i can hear a rattling noise coming from the engine, is this normal? It's a 07 track and I've only had the car 4 weeks so any kinda of noise coming from the engine freaks me out.
Old Dec 17, 2007 | 11:12 PM
sw0ng's Avatar
sw0ng
mine does that every time too lol, i think its normal
Old Dec 17, 2007 | 11:16 PM
Strider619's Avatar
Strider619
07 base here, 7.5k miles. no engine rattle when i turn it off.
Old Dec 17, 2007 | 11:18 PM
hieu's Avatar
hieu
Its normal. Try to press in the clutch when turning the engine off. =)
Old Dec 17, 2007 | 11:32 PM
terrasmak's Avatar
Duel mass flywheel , its normal.
Old Dec 18, 2007 | 12:55 AM
PFI350Z's Avatar
PFI350Z
mine does it... if you hold the clutch you wont hear it
Old Dec 18, 2007 | 01:07 AM
gsazabi's Avatar
gsazabi
Normal. Depress clutch while turning on the ignition like others said, problem solved.
This not only happens to dual-mass OEM clutch, but on single-mass aftermarket clutches as well.
Old Dec 18, 2007 | 01:09 AM
folddem's Avatar
folddem
What do you know... step on the clutch, turn off the engine and noise is not there this time ahhahaha... thanks guys.
Old Dec 18, 2007 | 01:46 AM
roast's Avatar
roast
Well the clutch is not "dual mass"... that would be the flywheel....
And the reason it happens to both is because it's not the flywheel.
It's normal and happens to a lot of manually equipped vehicles...
Old Dec 18, 2007 | 02:55 AM
Eazzy's Avatar
Eazzy
Pushing in the clutch before shutting down should just be a natural habit, if not, make it one.
I was sitting here racking my brain to recall, if I did or didnt and relized that it is such a natural habit I dont even think about it
Old Dec 18, 2007 | 03:51 AM
PFI350Z's Avatar
PFI350Z
Ever since I heard the rattling noise I aways hold my clutch as I turn the car off. Are you supposed to?
Old Dec 18, 2007 | 04:09 AM
Eazzy's Avatar
Eazzy
Personally, I would say so.....Turning off the ignition and letting the Crank,Cams,Valves,Pistons,Damper,Flywheel, come to a freewheeling stop makes more sense than adding to that, the Pressure Plate and Main Shaft Gear Cluster. Plus it would allow for a good Clutch Disk "center" in an unloaded state
Its just good Machine etiquette----A relaxed Machine is a Happy Machine
Old Dec 18, 2007 | 07:24 AM
mavtais's Avatar
mavtais
That makes sense to me. I'm glad I do that naturally then. I usually turn off my motor before I pull her out of 1st (sometimes even before I stop rolling). So yes, the clutch is depressed.
Old Dec 18, 2007 | 07:49 AM
68Stang's Avatar
68Stang
All you guys with depressed clutches.... Maybe you should look into group therapy?
Old Dec 18, 2007 | 07:55 AM
genegoesfast's Avatar
genegoesfast
wow^
Old Dec 18, 2007 | 12:33 PM
minispider's Avatar
minispider
mine is an '06. It has done this since day one
Old Dec 18, 2007 | 03:03 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
totally normal
sometimes when you start the engine there's a rattle as well. that's usually the timing chain (IIRC) and also normal. I had that sound on my maxima
Old Dec 18, 2007 | 11:29 PM
sw0ng's Avatar
sw0ng
thanks guys, amazing how many people encounter the same problems and how quickly solutions are made
Old Dec 19, 2007 | 03:20 AM
minispider's Avatar
minispider
I did the clutch thing before shutting down and the rattle is gone!!
Old Dec 19, 2007 | 03:51 AM
Eazzy's Avatar
Eazzy
Glad to hear that the problem was solved for some. There are a great many little habits picked up through the years that become so engrained, you dont think of them until someone brings them up. Those habits were learned through experimentation------Very little is engraved in stone and learning through doing things the wrong way, and seeing the results is the best teacher of all
