Car Stuck in Idle, Won't Rev At All
Old Jan 8, 2008 | 01:51 AM
LBkr's Avatar
LBkr
Default Car Stuck in Idle, Won't Rev At All
I spotted this thread but no others like it:
https://my350z.com/forum/engine-and-drivetrain/255044-engine-stumbling-will-idle-but-not-rev.html
but I'm not sure what's wrong with mine yet. Sounds similar.
For the record, I was in downtown Tampa traffic yesterday afternoon and my car went from normal driving to suddenly stuck in idle and wouldn't rev no matter what I did with the gas pedal. The dash lit up like a Christmas tree with the Slip, TCS, and Check Engine lights all coming on. After stopping for 2 minutes I got the engine to start up normally but it went back to idle just as soon as I put it in Drive (it's an auto trans and my daily driver). After 3 more minutes turned off, it started and ran normally so I went straight to the dealer. Everything was normal (all performance, all gauges, etc.) and while most warning lights went out, Check Engine stayed on.
I have an 04.5 with 31k on it. No performance mods yet besides a K&N filter. I'll let you know what the dealer says.
Anybody ever heard of being stuck in idle out of the blue while driving? Weird.
Old Jan 8, 2008 | 02:51 AM
MR RIZK's Avatar
MR RIZK
If the CEL is on there is a stored code in the ECU. This will help pin point the issue. Off the top of my head sensors that effect throttle control are TPS, CAS and the MAF.
You really need the code before u can move forward
Old Jan 8, 2008 | 03:19 AM
rcdash's Avatar
rcdash
... aka "limp mode"
Old Jan 8, 2008 | 04:44 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Mine acted like this when my TB went bad.
Old Jan 8, 2008 | 05:16 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i think you need more mods so it doesnt do it again
Old Jan 8, 2008 | 09:48 AM
GrayG35's Avatar
GrayG35
throttle body went bad. same happened to mine last year
Old Jan 8, 2008 | 10:06 AM
JoshuaJJackson's Avatar
JoshuaJJackson
This happened to my car just about a month ago. TB went bad if its still under warrenty they should fix it at no cost.
Old Jan 8, 2008 | 11:41 AM
LBkr's Avatar
LBkr
Bingo. TB. You guys were right.
Not under warranty. Throttle body had to be replaced. A throttle sensor went bad and can't be replaced separately. $310 with labor.
She goes fast again!
Old Jan 8, 2008 | 11:42 AM
LBkr's Avatar
LBkr
I'm sure that would help.
Just not sure where in central Florida I can get mods.
Old Jan 8, 2008 | 11:49 AM
k6750gsxr's Avatar
k6750gsxr
wow... must be tampa.... mine did that the other day while going home .... i unhooked the battery and started it back up... hasnt came on since....
what dealer did you take it to ?
Old Jan 8, 2008 | 11:51 AM
RedBullRR's Avatar
RedBullRR
Wait so its not covered under warranty or your warranty ran out? Just curious cause you have the same year car. I purchased the extended warranty.
Old Jan 8, 2008 | 12:21 PM
LBkr's Avatar
LBkr
Brandon Autoway.
Old Jan 8, 2008 | 12:22 PM
LBkr's Avatar
LBkr
My warranty ran out. Didn't buy an extension.
etkms
Jun 19, 2022 06:30 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Beater350z
Sep 9, 2015 03:36 PM
Darkspy
Sep 7, 2015 09:09 PM
