Motor Oil Change. Help!! Royal Purple??
Old Jan 14, 2008 | 02:39 PM
kida909's Avatar
kida909
Default Motor Oil Change. Help!! Royal Purple??
(disclaimer): This Is The First Time I Will Change Oil On Any Car.
I Have Heard Different Things About Different Motor Oils, And I Need To Make A Decision.
I Heard Royal Purple Is The Best And Gives Some Hp But May Damage Some Parts. Is This True?
I Heard Mobil 1 Sucks Now. (this Is What I Have Now)
Also, How Many Quarts Do I Buy And Use?
I Want To Install K&n Oil Filter, Any Tricks? (ex. Rub Oil Around Seal)
Please Shoot Me Some Insight Fella's.
I Have A Sick 03' 350z Touring Mt. 20' Staggered Axis W/ Nittos, Cool Air, Ibach Suspension, Nismo Exhaust
Old Jan 14, 2008 | 02:48 PM
The capital letters make my eyes go funny.
Old Jan 14, 2008 | 02:56 PM
Justinw1313's Avatar
Justinw1313
5 quarts is what Nissan recommends. I ran Royal Purple on all of my mustangs/ lightnings and I can tell you that you are not going to see any HP gains. I ran 500+Hp with one of my KB charger lightnings on royal purple and never had a failure. The K & N oil filter is nice because it has a grip. You don't want to tighten the filter with a filter wrench, because it can over tighten and wear the threads. You will want to put some oil on the oil filter gasket so you can get it off next time. Just check your dipstick after adding 5 quarts to make sure you have enough oil. I always run my car for at least 15 minutes before draining the old oil because hot oil will drain quicker. I think thats all the advice I have.
Old Jan 14, 2008 | 03:04 PM
kida909's Avatar
kida909
Thanks For The Help.
Will Royal Purple Damage Anything?
So Do I Just Hand Tighten The K&n?
Old Jan 14, 2008 | 03:08 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Read the following thread for a more comprehensive discussion on oil selection: https://my350z.com/forum/engine-and-drivetrain/258663-vq-oil-analysis-and-info.html
Old Jan 14, 2008 | 04:43 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by dkmura
Read the following thread for a more comprehensive discussion on oil selection: https://my350z.com/forum/showthread.php?t=258663
That thread is a good resource. Another resource is the top 100 questions thread. A third resource is the search function, as motor oil has been discussed in well over 100 threads I'm sure.
Also, to the OP please avoid typing with caps lock on. Thanks.
You want to do more than hand-tighten your oil filter. Use an oil filter wrench and tighten it about 1/4 turn past hand tight.
Replace the drain plug washer. That's about it. Nothing to it.
apex locator
Jul 23, 2021 02:27 AM
