Lightweight flywheel or Motordyne Plenum Spacer?
Old Jan 31, 2008 | 04:09 AM
theroo's Avatar
theroo
Default Lightweight flywheel or Motordyne Plenum Spacer?
I was wanting to buy an ACT prolite flywheel and a Motordyne 5/16" plenum spacer, but I decided to just pick one. There isn't much of a difference in price between the two. So which one would help me the most, and in which areas?
Old Jan 31, 2008 | 04:26 AM
Brrcats's Avatar
Brrcats
get the spacer for the powaahhhh
Old Jan 31, 2008 | 04:36 AM
RedBullRR's Avatar
RedBullRR
Well the Flywheel is not gonna be a cheap install, thats for sure.
Old Jan 31, 2008 | 04:37 AM
007|350Z's Avatar
007|350Z
+1 I would go spacer, the lessened mass of the flywheel helps, but I would rate the spacer higher. Not to mention easier...lol
Old Jan 31, 2008 | 04:45 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
Get the spacer....very easy to install and you will see a gain
Old Jan 31, 2008 | 04:55 AM
MichaelofHearts's Avatar
MichaelofHearts
Just making sure you know that with that spacer you aren't fitting the stock strut bar on, ethier way I'd go with the spacer.
Old Jan 31, 2008 | 06:45 AM
Reality350's Avatar
Reality350
Ummm, the 5/16th plenum spacer comes packaged with spacers for the strut bar..
I am not sure where you attained your information, but you are incorrect.
Search is your friend....
Oh, get the spacer...
Old Jan 31, 2008 | 08:47 AM
bbs350z's Avatar
bbs350z
a cluth/flywheel package will run you $600-$800 + installation, so itll be around $1300 give or take. get the spacer
Old Jan 31, 2008 | 09:06 AM
ke0ki2k's Avatar
ke0ki2k
isnt much difference in price? the flywheel is like twice the price of the 5/16th inch spacer...but yeah do the spacer, unless your clutch is burnt up & needs to get replaced anyhow.
Old Jan 31, 2008 | 09:11 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
flywheel...........So i Can be diff
Old Jan 31, 2008 | 10:03 AM
Yujimbo's Avatar
Yujimbo
i just got a spacer in today gonna put it on tomorrow or tonight. I got the 5/16 iso thermal it shouldn't need a diff strut bar Is what I was told. correct?
Old Jan 31, 2008 | 10:55 AM
realdealg35's Avatar
realdealg35
I'd get the flywheel personally. The spacer would give a power increase, but the lighter flywheel would show a power increase and allow the car to rev faster - get into the powerband faster. Between a flywheel and a spacer, I'd say the flywheel is going to give you more bang, but it's a bit more expensive. You might want to do it when you need to replace the clutch, like others have said.
Old Jan 31, 2008 | 11:46 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Correct. You can use your stock strut bar with it.
Old Jan 31, 2008 | 12:18 PM
Yujimbo's Avatar
Yujimbo
thanks my friends at motordyne. I picked your product over the new one that intensepower came out with, it seems more reliable.
Old Jan 31, 2008 | 12:34 PM
Frostydc4's Avatar
Frostydc4
Honestly, if you don't mind the cost I'd go for the flywheel. The improvement will be very noticeable.
Old Jan 31, 2008 | 10:10 PM
Eazzy's Avatar
Eazzy
Iv installed a bunch and MD is the only way to go
Old Feb 3, 2008 | 02:56 PM
cshih2's Avatar
cshih2
for the spacer, which one should i get?! as details as possible.
thx alot!
Old Feb 3, 2008 | 02:59 PM
blasian's Avatar
blasian
Can you even use the stock clutch with an ACT flywheel?
+1 on flywheel install. IMO, it would be a waste to get a flywheel installed without getting an aftermarket clutch
Old Feb 3, 2008 | 03:14 PM
Hydrazine's Avatar
Hydrazine
thx alot!
If you live in Buffalo NY, there is no question you should get the Copper version.
Old Feb 3, 2008 | 04:30 PM
kirradude1025's Avatar
kirradude1025
I was gonna get the spacer, but I got a CF Seibon Front Lip TT Style today. Next mod is most likely going to be the spacer.
